No low battery notification and my computer always just shuts off, I have all the right settings on
2010-05-19T07:07:41+00:00
I purchased my laptop now for about 6 months and the most annoying part is that there is never a low battery notification before my laptop hibernates. It has never shown up once.
The battery meter is active and shown in my system tray. I have gone into power options, changed advanced battery options for low, critical, and reserve levels as well as turned ON low battery notification. In system tray properties > notification area > customize > I have also selected "show icon and notifications".
The windows 7 microsoft website as well as many other forums only suggest to do these 2 things. I HAVE done these two things, as they were the original settings when I bought this laptop new...what else can I do? Is there a patch, download, anything?! I would rather not have to install 3rd party software. I would just like my laptop to function properly. I am not a heavy gamer or student, I just use my laptop to surf the web and watch videos. I also use free Avira antivirus, if any of this is important to why a battery notification won't show up.
Edit: My friend and I bought the exact same computer on the same day. His shows notifications and mine doesn't, so I know it's possible.
2014-11-25T13:08:22+00:00
Just open your
"control panel"
and then "power option" then
"change advance power settings"
there select  the profile you want to active( power saver ,high performance etc.)
Then scroll down to "battery" expand it and find "low battery notification" and turn  "on" for both "on battery" and "plugged in"  and you will done.
Note :- not necessary to turn it on for "plugged in"
81 additional answers
    2016-01-07T19:08:36+00:00
    I've reset the Windows 10 low battery notification many times and it will not work.  Instead, my laptop just keeps suddenly shutting down with no warning.  I didn't have this problem with Windows 7, which actually worked.  Should I just give up and go back to Windows 7?
    2015-11-08T19:52:29+00:00
    I own the Acer 7741Z with a brand new hard drive and new install of Win 7 64 bit.  Mine laptop does the same this as everyone elses here.  So Microsoft, what am I to do now?
    2015-11-08T05:29:03+00:00
    My HP laptop suddenly stopped notifying me of low battery, too.  It does exactly what yours does, Jucasa1933.
    2015-10-01T23:33:00+00:00
