I purchased my laptop now for about 6 months and the most annoying part is that there is never a low battery notification before my laptop hibernates. It has never shown up once.
The battery meter is active and shown in my system tray. I have gone into power options, changed advanced battery options for low, critical, and reserve levels as well as turned ON low battery notification. In system tray properties > notification area > customize > I have also selected "show icon and notifications".
The windows 7 microsoft website as well as many other forums only suggest to do these 2 things. I HAVE done these two things, as they were the original settings when I bought this laptop new...what else can I do? Is there a patch, download, anything?! I would rather not have to install 3rd party software. I would just like my laptop to function properly. I am not a heavy gamer or student, I just use my laptop to surf the web and watch videos. I also use free Avira antivirus, if any of this is important to why a battery notification won't show up.
Edit: My friend and I bought the exact same computer on the same day. His shows notifications and mine doesn't, so I know it's possible.
It sounds like because you didn't see the notifaction about your laptop getting low on power and then shutting down with out any warnning.? I have also had this problem.. but you see when you go into the advanched setting and change it a little, it then
stops working alltogether... May I say also there is a warnning message what will apper when something is, or will be changed.?
Your best option is to use system restore and restore your windows 7 back to say a week.? or two weeks, using this option will refresh your laptop back to a weeks date in the os sytem info which will allteritively reset the wrong setting that the os may
have fault with.? I use windows 7 Professional on my Desktop and i have used this before with getting help with some issue's.
I hope this may be of some us.
Many Regards,
Mr Francis Hayle.
