No low battery notification and my computer always just shuts off, I have all the right settings on
2010-05-19T07:07:41+00:00
I purchased my laptop now for about 6 months and the most annoying part is that there is never a low battery notification before my laptop hibernates. It has never shown up once.
The battery meter is active and shown in my system tray. I have gone into power options, changed advanced battery options for low, critical, and reserve levels as well as turned ON low battery notification. In system tray properties > notification area > customize > I have also selected "show icon and notifications".
The windows 7 microsoft website as well as many other forums only suggest to do these 2 things. I HAVE done these two things, as they were the original settings when I bought this laptop new...what else can I do? Is there a patch, download, anything?! I would rather not have to install 3rd party software. I would just like my laptop to function properly. I am not a heavy gamer or student, I just use my laptop to surf the web and watch videos. I also use free Avira antivirus, if any of this is important to why a battery notification won't show up.
Edit: My friend and I bought the exact same computer on the same day. His shows notifications and mine doesn't, so I know it's possible.
2014-11-25T13:08:22+00:00
Just open your
"control panel"
and then "power option" then
"change advance power settings"
there select  the profile you want to active( power saver ,high performance etc.)
Then scroll down to "battery" expand it and find "low battery notification" and turn  "on" for both "on battery" and "plugged in"  and you will done.
Note :- not necessary to turn it on for "plugged in"
81 additional answers
    2014-05-08T09:58:15+00:00
    I am not sure if this issue has been resolved yet, but after I have been doing almost all the fixes that were suggested by users from various forums I have come across a button I haven't noticed before in the power settings.
    If you go to the battery icon in the system tray -> right click -> power options -> the power option window pops up. Next to any default power plan, (usually Power Saver; Balanced; High Performance) select the "Change Plan Settings" text. Another window opens up. Select the "Change advanced power settings" text at the bottom of the window. At the top of the new window you will see a drop down menu with the 3 default power plans as options. <- Keep this in mind as you need to do the following with all the power plan settings.
    Next Click the "Restore Plan Defaults" button. Confirm it by clicking "Yes".
    Now do this with all the power plans in the drop down menu mentioned above.
    It fixed my issue with the battery low notification that stopped displaying.
    * Note: If you have recently replaced your battery because the previous one was "used up" / faulty, you might remember a popup that told you that the battery needs replacement. If you clicked the option of "Don't display this message again" / "Don't display battery replacement notifications" it could've been the origin of the problem.
    Regards
    2012-08-30T14:51:34+00:00
    Hello!
    1. right click on the start butten & click properties
    2. under the taskbar menu click customize
    3. on the new window choose power options and select show icon and notificationsand **** click ok.
    Hope that helps!
    2011-05-16T01:11:05+00:00
    Try to set the Low Battery notification to a higher percentage.  See if this helps, and if not, you should reinstall Windows.  Other stuff like this is available at:  http://www.waltwachon.weebly.com
    2010-05-19T23:41:54+00:00
    a. Have you tried using a different battery on this laptop?
    Method 1.
    You can run the Power troubleshooter to adjust your computer's power settings. The Power troubleshooter checks things like your computer's timeout settings, which determine how long the computer waits before turning off the monitor display or entering sleep mode. Adjusting these settings can help you conserve power and extend your computer's battery life.
    Refer to the article below for steps.
    Open the Power troubleshooter
    http://windows.microsoft.com/en-US/windows7/Open-the-Power-troubleshooter
    **Method 2.**Have you performed the steps listed under "My laptop shuts down or goes into hibernation too soon after the low-battery notification appears, or the low-battery notification never appears." in the article below?
    Solutions to common power problem
    http://windows.microsoft.com/en-US/windows7/Solutions-to-common-power-problems
    Hope this helps.
    Thanks and Regards:
    Shekhar S - Microsoft Support. Visit our Microsoft Answers Feedback Forum and let us know what you think.
    If this post helps to resolve your issue, please click the "Mark as Answer" or "Helpful" button at the top of this message. By marking a post as Answered, or Helpful you help others find the answer faster.
