No low battery notification and my computer always just shuts off, I have all the right settings on
2010-05-19T07:07:41+00:00
I purchased my laptop now for about 6 months and the most annoying part is that there is never a low battery notification before my laptop hibernates. It has never shown up once.
The battery meter is active and shown in my system tray. I have gone into power options, changed advanced battery options for low, critical, and reserve levels as well as turned ON low battery notification. In system tray properties > notification area > customize > I have also selected "show icon and notifications".
The windows 7 microsoft website as well as many other forums only suggest to do these 2 things. I HAVE done these two things, as they were the original settings when I bought this laptop new...what else can I do? Is there a patch, download, anything?! I would rather not have to install 3rd party software. I would just like my laptop to function properly. I am not a heavy gamer or student, I just use my laptop to surf the web and watch videos. I also use free Avira antivirus, if any of this is important to why a battery notification won't show up.
Edit: My friend and I bought the exact same computer on the same day. His shows notifications and mine doesn't, so I know it's possible.
2014-11-25T13:08:22+00:00
Just open your
"control panel"
and then "power option" then
"change advance power settings"
there select  the profile you want to active( power saver ,high performance etc.)
Then scroll down to "battery" expand it and find "low battery notification" and turn  "on" for both "on battery" and "plugged in"  and you will done.
Note :- not necessary to turn it on for "plugged in"
81 additional answers
    2010-06-04T11:54:26+00:00
    To Shekhar S:
    Neither method 1 or 2 did anything to help the problem. Method one just told me to turn on a screen saver as a suggestion after running the troubleshooter. I HAVE read the article presented in method 2, but again...does not apply. My laptop low-battery notification never appears, but the settings are correct as mentioned in that article.
    I repeat: my battery settings are set to have low battery level at 10% AND to show a notification. IT just never shows up! What is wrong microsoft?! So frustrating.
    It seems many people have this problem in this forum, any solutions yet?
    2011-05-15T23:31:24+00:00
    ANY HELP?!?! It's been ONE WHOLE YEAR?!?!?!?!?!?!? C'mon guys, a point of a forum is to be helpful not give the same FAQ answers like a robot.
    2011-01-05T18:43:54+00:00
    I've got an HP Pavilion with Windows Vista Home Premium, and I see no way to get a Low Battery Alert.  Maybe the little icon in the corner is flashing or something, but I don't notice it.  Windows will suddenly shut down or or the laptop will power off and I will lose work because I THOUGHT the power was plugged in.  This has happened several times now.
    The only way I can see to fix it is to have a visible alert message pop up on screen in an always on top window informing me that I'm at Low and Critical battery levels.  Is there a way to accomplish this?
    James
    2014-11-25T13:03:02+00:00
    Just open your
    "control panel"
