Download and install the latest nVidia driver for your graphics card.
I click "Address a problem with NVIDIA graphics driver" and it says "This solution could not be downloaded".
I click on solve PC issues (the flag) and it says Address a problem with NVIDIA graphics driver. I click it and it says
Most likely causes:
Your computer was unable to download the solution at this time. Check to make sure your computer is connected to the Internet, and then try to download the solution again later.
I am connected to the internet, and windows update works, web browsing works etc. Why isn't it downloading the solution?
71 additional answers
2010-03-28T08:58:03+00:00 I click on solve PC issues (the flag) and it says Address a problem with NVIDIA graphics driver. I click it and it says
Most likely causes:
hi i am getting the same problem as all the others with my system freezing this is the saved dxdiag as requested
System Information
Time of this report: 3/28/2010, 09:51:07
Machine name: ZION
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
Language: English (Regional Setting: English)
System Manufacturer: MEDIONPC
System Model: MS-7502
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Pentium(R) Dual-Core CPU E5300 @ 2.60GHz (2 CPUs), ~2.6GHz
Memory: 6144MB RAM
Available OS Memory: 6142MB RAM
Page File: 1628MB used, 10654MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: The file MAudioFastTrackPro.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 2: The file MAudioFastTrackPro.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Sound Tab 5: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GT 220
Manufacturer: NVIDIA
Chip type: GeForce GT 220
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0A20&SUBSYS_20201462&REV_A2
Display Memory: 3821 MB
Dedicated Memory: 1006 MB
Shared Memory: 2815 MB
Current Mode: 1824 x 1026 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: SONY TV
Monitor Id: SNY7001
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 8.16.0011.9062 (English)
Driver Version: 8.16.11.9062
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 8/16/2009 23:57:00, 9380352 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-4960-11CF-B454-2B001DC2C535}
Vendor ID: 0x10DE
Device ID: 0x0A20
SubSys ID: 0x20201462
Revision ID: 0x00A2
Driver Strong Name: oem1.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section011:8.16.11.9062:pci\ven_10de&dev_0a20&subsys_20201462
Rank Of Driver: 00E60001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Line 1/2 (M-Audio FastTrack Pro)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: USB\VID_0763&PID_2012&REV_0100
Manufacturer ID: 239
Product ID: 65535
Type: WDM
Driver Name: MAudioFastTrackPro.sys
Driver Version: 5.10.0000.5134 (English)
WHQL Logo'd: No
Date and Size: 11/9/2009 14:56:20, 187912 bytes
Other Files:
Driver Provider: M-Audio
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: S/PDIF (M-Audio FastTrack Pro)
Default Sound Playback: No
Default Voice Playback: No
Product ID: 65535
Type: WDM
WHQL Logo'd: No
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Description: SONY TV-1 (NVIDIA High Definition Audio)
Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_000A&SUBSYS_10DE0101&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: nvhda64v.sys
Driver Version: 1.00.0000.0059 (English)
WHQL Logo'd: Yes
Date and Size: 8/21/2009 21:24:04, 84512 bytes
Other Files:
Driver Provider: NVIDIA Corporation
Cap Flags: 0xF1F
HW Memory: 0
Description: Speakers (High Definition Audio Device)
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_1462502A&REV_1001
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.01.7600.16385 (English)
WHQL Logo'd: Yes
Date and Size: 7/14/2009 01:07:00, 350208 bytes
Other Files:
Driver Provider: Microsoft
Cap Flags: 0xF1F
HW Memory: 0
Description: Digital Audio (S/PDIF) (High Definition Audio Device)
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Line 3/4 (M-Audio FastTrack Pro)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
- USB Root Hub
| Vendor/Product ID: 0x8086, 0x2934
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 7/14/2009 01:07:09, 343040 bytes
| Driver: usbd.sys, 7/14/2009 01:06:23, 7936 bytes
+-+ USB Input Device
| | Vendor/Product ID: 0x055D, 0x1030
| | Matching Device ID: generic_hid_device
| | Service: HidUsb
| | Driver: hidusb.sys, 7/14/2009 01:06:22, 30208 bytes
| | Driver: hidclass.sys, 7/14/2009 01:06:21, 76288 bytes
| | Driver: hidparse.sys, 7/14/2009 01:06:17, 32896 bytes
| +-+ HID-compliant mouse
| | | Matching Device ID: hid_device_system_mouse
| | | Service: mouhid
| | | Driver: mouhid.sys, 7/14/2009 01:00:20, 31232 bytes
| | | Driver: mouclass.sys, 7/14/2009 02:48:27, 49216 bytes
Gameport Devices
PS/2 Devices
- Standard PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 7/14/2009 00:19:57, 105472 bytes
| Driver: kbdclass.sys, 7/14/2009 02:48:04, 50768 bytes
- Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
- Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 7/14/2009 02:45:55, 62544 bytes
| Driver: sermouse.sys, 7/14/2009 01:00:20, 26624 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 387.6 GB
Total Space: 450.2 GB
File System: NTFS
Model: ST3500412AS ATA Device
Drive: D:
Free Space: 11.6 GB
Total Space: 25.6 GB
File System: NTFS
Drive: G:
Free Space: 461.1 GB
Total Space: 715.4 GB
File System: NTFS
Model: Maxtor OneTouch USB Device
Drive: E:
Model: HL-DT-ST DVDRAM GH22NS40 ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (English), 7/14/2009 00:19:54, 147456 bytes
System Devices
Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A
Device ID: PCI\VEN_8086&DEV_293A&SUBSYS_75021462&REV_02\3&2411E6FE&1&EF
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7600.16385 (English), 7/14/2009 01:06:30, 51200 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7600.16385 (English), 7/14/2009 01:06:31, 324608 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7600.16385 (English), 7/14/2009 01:07:09, 343040 bytes
Name: Standard AHCI 1.0 Serial ATA Controller
Device ID: PCI\VEN_8086&DEV_2922&SUBSYS_75021462&REV_02\3&2411E6FE&1&FA
Driver: C:\Windows\system32\DRIVERS\msahci.sys, 6.01.7600.16385 (English), 7/14/2009 02:48:27, 30272 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/14/2009 02:45:46, 48720 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/14/2009 02:52:21, 24128 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7600.16385 (English), 7/14/2009 02:52:21, 155728 bytes
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2939
Device ID: PCI\VEN_8086&DEV_2939&SUBSYS_75021462&REV_02\3&2411E6FE&1&D2
Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7600.16385 (English), 7/14/2009 01:06:27, 30720 bytes
Name: Intel(R) ICH9DH LPC Interface Controller - 2912
Device ID: PCI\VEN_8086&DEV_2912&SUBSYS_75021462&REV_02\3&2411E6FE&1&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 02:48:27, 15424 bytes
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2938
Device ID: PCI\VEN_8086&DEV_2938&SUBSYS_75021462&REV_02\3&2411E6FE&1&D1
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_75021462&REV_92\3&2411E6FE&1&F0
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7600.16385 (English), 7/14/2009 02:45:45, 183872 bytes
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2937
Device ID: PCI\VEN_8086&DEV_2937&SUBSYS_75021462&REV_02\3&2411E6FE&1&D0
Name: Intel(R) 82562V-2 10/100 Network Connection
Device ID: PCI\VEN_8086&DEV_10C0&SUBSYS_502C1462&REV_02\3&2411E6FE&1&C8
Driver: C:\Windows\system32\DRIVERS\e1e6032e.sys, 9.13.0004.0010 (English), 6/10/2009 21:35:20, 278016 bytes
Name: Intel(R) G33/G31/P35/P31 Express Chipset PCI Express Root Port - 29C1
Device ID: PCI\VEN_8086&DEV_29C1&SUBSYS_75021462&REV_02\3&2411E6FE&1&08
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2936
Device ID: PCI\VEN_8086&DEV_2936&SUBSYS_75021462&REV_02\3&2411E6FE&1&EA
Name: VIA 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_502D1462&REV_C0\4&35B52530&0&10F0
Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7600.16385 (English), 7/14/2009 01:07:13, 227840 bytes
Name: Intel(R) G33/G31/P35/P31 Express Chipset Processor to I/O Controller - 29C0
Device ID: PCI\VEN_8086&DEV_29C0&SUBSYS_29C08086&REV_02\3&2411E6FE&1&00
Driver: n/a
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2935
Device ID: PCI\VEN_8086&DEV_2935&SUBSYS_75021462&REV_02\3&2411E6FE&1&E9
Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_0BE2&SUBSYS_20201462&REV_A1\4&35F60EBB&0&0108
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7600.16385 (English), 7/14/2009 01:06:13, 122368 bytes
Device ID: PCI\VEN_8086&DEV_293E&SUBSYS_502A1462&REV_02\3&2411E6FE&1&D8
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2934
Device ID: PCI\VEN_8086&DEV_2934&SUBSYS_75021462&REV_02\3&2411E6FE&1&E8
Name: NVIDIA GeForce GT 220
Device ID: PCI\VEN_10DE&DEV_0A20&SUBSYS_20201462&REV_A2\4&35F60EBB&0&0008
Driver: C:\Windows\System32\DriverStore\FileRepository\nvmo.inf_amd64_neutral_97ee240bfa362144\NvCplSetupInt.exe, 14.00.0000.0162 (English), 8/16/2009 23:57:00, 41269901 bytes
Driver: C:\Windows\system32\DRIVERS\nvBridge.kmd, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 11168 bytes
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 11313312 bytes
Driver: C:\Windows\system32\dpinst.exe, 2.01.0000.0000 (English), 8/16/2009 23:57:00, 930272 bytes
Driver: C:\Windows\system32\nvapi64.dll, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 1292800 bytes
Driver: C:\Windows\system32\nvcuda.dll, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 2619392 bytes
Driver: C:\Windows\system32\nvcuvenc.dll, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 1723424 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 2258976 bytes
Driver: C:\Windows\system32\nvd3dumx.dll, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 9380352 bytes
Driver: C:\Windows\system32\nvdecodemft.dll, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 315936 bytes
Driver: C:\Windows\system32\nvdisp.nvu, 8/16/2009 23:57:00, 10744 bytes
Driver: C:\Windows\system32\nvencodemft.dll, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 2116096 bytes
Driver: C:\Windows\system32\nvoglv64.dll, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 15007744 bytes
Driver: C:\Windows\system32\nvudisp.exe, 1.09.0037.0015 (English), 8/16/2009 23:57:00, 541216 bytes
Driver: C:\Windows\system32\nvwgf2umx.dll, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 4583936 bytes
Driver: C:\Windows\SysWow64\nvapi.dll, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 1044992 bytes
Driver: C:\Windows\SysWow64\nvcuda.dll, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 1985536 bytes
Driver: C:\Windows\SysWow64\nvcuvenc.dll, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 1706528 bytes
Driver: C:\Windows\SysWow64\nvcuvid.dll, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 2169376 bytes
Driver: C:\Windows\SysWow64\nvd3dum.dll, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 7569920 bytes
Driver: C:\Windows\SysWow64\nvdecodemft.dll, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 252448 bytes
Driver: C:\Windows\SysWow64\nvencodemft.dll, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 1919520 bytes
Driver: C:\Windows\SysWow64\nvoglv32.dll, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 10858496 bytes
Driver: C:\Windows\SysWow64\nvwgf2um.dll, 8.16.0011.9062 (English), 8/16/2009 23:57:00, 3298304 bytes
Driver: C:\Windows\system32\nvcod.dll, 1.06.0002.0057 (English), 8/16/2009 23:57:00, 173568 bytes
Driver: C:\Windows\system32\nvcod162.dll, 1.06.0002.0057 (English), 8/16/2009 23:57:00, 173568 bytes
Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C
Device ID: PCI\VEN_8086&DEV_293C&SUBSYS_75021462&REV_02\3&2411E6FE&1&D7
Name: Intel(R) ICH9 Family SMBus Controller - 2930
Device ID: PCI\VEN_8086&DEV_2930&SUBSYS_75021462&REV_02\3&2411E6FE&1&FB
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7600.16385
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7600.16385
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7600.16385
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7600.16385
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7600.16385
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.00.0007.3010
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.00.0007.3010
ffdshow Audio Decoder,0x3fffffff,1,1,ffdshow.ax,1.00.0007.3010
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7600.16385
MPC - Mpeg Source (Gabest),0x00400000,0,0,MpegSplitter.ax,1.02.1164.0000
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7600.16490
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7600.16385
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7600.16385
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7600.16490
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7600.16490
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
MPC - RealVideo Decoder,0x00600000,1,1,RealMediaSplitter.ax,1.02.1160.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7600.16385
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7600.16385
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7600.16490
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7600.16385
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7600.16385
MPC - MP4 Source,0x00600000,0,0,MP4Splitter.ax,1.02.1160.0000
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7600.16385
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
MPC - FLV Splitter (Gabest),0x00600000,1,1,FlvSplitter.ax,1.02.1160.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7600.16490
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7600.16385
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7600.16490
Haali Media Splitter,0x00800001,0,1,splitt
2010-02-19T00:40:24+00:00 Does anyone know where to go to get the solutions that are flagged in the "Action Center"?
My Action centre tells me that it has solutions to a couple of issues that are plaguing my System 7 installation but each time I open it and click on "Solution" I get the message:
"Your computer was unable to download the solution at this time. Check to make sure your computer is connected to the Internet, and then try to download the solution again later."
And yes, I am connected to the internet at the time.
2010-02-16T20:53:36+00:00 "I click on solve PC issues (the flag) and it says Address a problem with NVIDIA graphics driver. I click it and it says
"I am connected to the internet, and windows update works, web browsing works etc. Why isn't it downloading the solution?"
I am having the exact same problem.... Since upgrading to system 7(64 bit) from Vista 64, my previously stable PC crashes or freezes at irregular intervals. PC is Asus CG5270 and graphics card is Nvidia GT220. Latest drivers via Microsoft Update are 8.17.11.9621.
The little flag tells me that someone has the solution, but it is infuriating that I cannot get to that answer! DominicP's answer to download latest drivers is not the solution as I ALREADY have the latest drivers! In fact I have tried rolling back through all the 190 series drivers and they all cause crashes. Only the 180 series drivers give stability, but they run Windows in a narrowed display on my Envision flat screen. (2" black vertical stripes on either side of the display)
2010-02-15T21:58:51+00:00 For those of you how have a standard "desktop" / "tower" PC,
http://www.nvidia.com/Download/index5.aspx?lang=en-us
For those who have laptops, first check with the manufacturer. If they do not have any Windows 7 drivers, consult with
and look at the web forums for more help.
