Download and install the latest nVidia driver for your graphics card.
I click "Address a problem with NVIDIA graphics driver" and it says "This solution could not be downloaded".
I click on solve PC issues (the flag) and it says Address a problem with NVIDIA graphics driver. I click it and it says
Most likely causes:
Your computer was unable to download the solution at this time. Check to make sure your computer is connected to the Internet, and then try to download the solution again later.
I am connected to the internet, and windows update works, web browsing works etc. Why isn't it downloading the solution?
71 additional answers
2010-02-14T21:19:26+00:00 I have also got the same problem . How do u download and install the latest nVidia driver for your graphics card?
2010-02-11T18:38:29+00:00 Hi,
If you are having this issue, pleae reply with the hardware ID for your Nvidia card. To get that you can run dxdiag and save a log. Then paste this section.
Display Devices
Chris [MSFT]
2010-02-11T07:55:03+00:00 I have same problem! SOMEBODY FIX IT!!
2010-01-28T12:35:21+00:00 Doesn't fix problem
