Download and install the latest nVidia driver for your graphics card.
I click "Address a problem with NVIDIA graphics driver" and it says "This solution could not be downloaded".
I click on solve PC issues (the flag) and it says Address a problem with NVIDIA graphics driver. I click it and it says
Most likely causes:
Your computer was unable to download the solution at this time. Check to make sure your computer is connected to the Internet, and then try to download the solution again later.
I am connected to the internet, and windows update works, web browsing works etc. Why isn't it downloading the solution?
71 additional answers
2011-09-08T22:38:43+00:00 i have the same problem, ho can i fix that?
2011-09-08T20:27:41+00:00 I click on solve PC issues (the flag) and it says Address a problem with NVIDIA graphics driver. I click it and it says
Most likely causes:
just archive message, than it goes away
Deleted
2011-08-27T13:25:26+00:00 This is still a problem with NVIDIA GeForce GTX 465
dxdiag reports no problems found but Action Center shows an issue and errors when it tries to download update
My graphics driver is the latest from NVIDIA
