I click "Address a problem with NVIDIA graphics driver" and it says "This solution could not be downloaded".
2009-12-14T04:08:32+00:00
I click on solve PC issues (the flag) and it says Address a problem with NVIDIA graphics driver. I click it and it says
Most likely causes:
Your computer was unable to download the solution at this time. Check to make sure your computer is connected to the Internet, and then try to download the solution again later.
I am connected to the internet, and windows update works, web browsing works etc. Why isn't it downloading the solution?
2009-12-14T07:50:49+00:00
Download and install the latest nVidia driver for your graphics card.
71 additional answers
    2011-08-15T19:55:48+00:00
    If you are having this issue, pleae reply with the hardware ID for your Nvidia card. To get that you can run dxdiag and save a log. Then paste this section.
    Display Devices
    Chris [MSFT]
    Display Devices
    Card name: NVIDIA GeForce GTX 550 Ti
    Manufacturer: NVIDIA
    Chip type: GeForce GTX 550 Ti
    DAC type: Integrated RAMDAC
    Device Key: Enum\PCI\VEN_10DE&DEV_1244&SUBSYS_15573842&REV_A1
    Display Memory: 4064 MB
    Dedicated Memory: 992 MB
    Shared Memory: 3071 MB
    Current Mode: 1920 x 1080 (32 bit) (60Hz)
    Monitor Name: S211HL (Analog)
    Monitor Model: S211HL
    Monitor Id: ACR01AA
    Native Mode: 1920 x 1080(p) (60.000Hz)
    Output Type: DVI
    Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
    Driver File Version: 8.17.0012.8026 (English)
    Driver Version: 8.17.12.8026
    DDI Version: 11
    Driver Model: WDDM 1.1
    Driver Attributes: Final Retail
    Driver Date/Size: 8/3/2011 07:50:00, 15064168 bytes
    WHQL Logo'd: Yes
    WHQL Date Stamp:
    Device Identifier: {D7B71E3E-5104-11CF-A844-5B351FC2C535}
    Vendor ID: 0x10DE
    Device ID: 0x1244
    SubSys ID: 0x15573842
    Revision ID: 0x00A1
    Driver Strong Name: oem18.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section005:8.17.12.8026:pci\ven_10de&dev_1244
    Rank Of Driver: 00E62001
    Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
    Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    D3D9 Overlay: Supported
    DXVA-HD: Supported
    DDraw Status: Enabled
    D3D Status: Enabled
    AGP Status: Enabled
    Current Mode: 1440 x 900 (32 bit) (60Hz)
    Monitor Name: Dell SE198WFP(Analog)
    Monitor Model: DELL SE198WFP
    Monitor Id: DELF003
    Native Mode: 1440 x 900(p) (59.887Hz)
    Output Type: HD15
    DDI Version: 11
    WHQL Logo'd: Yes
    WHQL Date Stamp:
    Vendor ID: 0x10DE
    Device ID: 0x1244
    Revision ID: 0x00A1
    DXVA-HD: Supported
    D3D Status: Enabled
    AGP Status: Enabled
    2011-08-01T04:54:22+00:00
    Display Devices
    Chris [MSFT]
    Display Devices
              Card name: NVIDIA GeForce GTX 480
              Chip type: GeForce GTX 480
             Device Key: Enum\PCI\VEN_10DE&DEV_06C0&SUBSYS_14803842&REV_A3
         Display Memory: 4063 MB
       Dedicated Memory: 1503 MB
          Shared Memory: 2559 MB
           Current Mode: 1920 x 1200 (32 bit) (59Hz)
           Monitor Name: SyncMaster 275T(Digital)
          Monitor Model: SyncMaster
             Monitor Id: SAM029A
            Native Mode: 1920 x 1200(p) (59.950Hz)
            Output Type: DVI
    Driver File Version: 8.17.0012.7550 (English)
         Driver Version: 8.17.12.7550
            DDI Version: 11
       Driver Date/Size: 6/15/2011 07:11:00, 15224424 bytes
            WHQL Logo'd: n/a
        WHQL Date Stamp: n/a
      Device Identifier: {D7B71E3E-4580-11CF-8C46-8C341DC2C535}
              Vendor ID: 0x10DE
              Device ID: 0x06C0
              SubSys ID: 0x14803842
            Revision ID: 0x00A3
     Driver Strong Name: oem5.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section005:8.17.12.7550:pci\ven_10de&dev_06c0
         Rank Of Driver: 80E62001
                DXVA-HD: Supported
             D3D Status: Enabled
             AGP Status: Enabled
    2011-08-01T04:11:31+00:00
    Display Devices
    Chris [MSFT]
    Hi Chris, I have this issue, so here is the Display Devices section on my laptop:
    Display Devices
              Card name: NVIDIA GeForce GT 330M
              Chip type: GeForce GT 330M
             Device Key: Enum\PCI\VEN_10DE&DEV_0A29&SUBSYS_FD301179&REV_A2
         Display Memory: 2743 MB
       Dedicated Memory: 986 MB
          Shared Memory: 1757 MB
           Current Mode: 1366 x 768 (32 bit) (60Hz)
           Monitor Name: Generic PnP Monitor
          Monitor Model: unknown
             Monitor Id: SEC3641
            Native Mode: 1366 x 768(p) (59.998Hz)
            Output Type: Internal
    Driver File Version: 8.17.0012.6658 (English)
         Driver Version: 8.17.12.6658
            DDI Version: 10.1
       Driver Date/Size: 1/7/2011 23:27:00, 12859496 bytes
            WHQL Logo'd: Yes
        WHQL Date Stamp:
      Device Identifier: {D7B71E3E-4969-11CF-CB68-3CDD1CC2C535}
              Vendor ID: 0x10DE
              Device ID: 0x0A29
              SubSys ID: 0xFD301179
            Revision ID: 0x00A2
     Driver Strong Name: oem41.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section004:8.17.12.6658:pci\ven_10de&dev_0a29&subsys_fd301179
         Rank Of Driver: 00E60001
                DXVA-HD: Supported
             D3D Status: Enabled
             AGP Status: Enabled
    Jean-Louis
    2011-07-27T13:21:31+00:00
    Would you please elaborate on your reply?I have a "factory fresh" laptop with the same problem,
