Download and install the latest nVidia driver for your graphics card.
I click "Address a problem with NVIDIA graphics driver" and it says "This solution could not be downloaded".
I click on solve PC issues (the flag) and it says Address a problem with NVIDIA graphics driver. I click it and it says
Most likely causes:
Your computer was unable to download the solution at this time. Check to make sure your computer is connected to the Internet, and then try to download the solution again later.
I am connected to the internet, and windows update works, web browsing works etc. Why isn't it downloading the solution?
71 additional answers
2010-01-28T12:34:10+00:00 I have had this problem since installing the Windows 7 update. My drivers are also updated to the most recent. The real issue here is that the Action Center is unable to download any solutions and mistakenly believes there is no internet connection. This issue also seems to cause some other minor issues with the system but is managable. I thought Microsoft or Nvidia would have come up with a solution based on the number of error reports my system has sent in to the product improvement people.
2010-01-15T23:30:31+00:00 i also have this problem and the driver is already up to date ??
it appears its not a big issue but i wish it would go away
2010-01-07T22:06:46+00:00 This is not a solution to the proposed problem.
2010-01-06T14:57:47+00:00 I have the same thing. And I already have the latest NVIDIA driver (195.62, WHQL).
Or with latest do you mean the beta (non-WHQL) driver? With Flash acceleration support?
And it would also be nice to know why it isn't downloading the solution?
