Wireless Network Will Not Connect Automatically On Boot
2010-02-12T14:42:33+00:00
I have Windows 7 Professional.  Every time I boot up I have to to click on wireless icon & enter code key to connect to net.  When I go to Network & Sharing Center, active network is showing.  When I go to Manage Wireless Networks, active network not listed.  When I try to manually add it, I fill in all data and click next, I get notice that access is denied. I have admin. rights. Have talked w/HP & router people to no avail.  Just need to find fix that will automatically connect to internet on boot without necessity of entering key code each time I boot up.  Would greatly appreciate any suggestions.
2010-10-16T12:41:36+00:00
open search, type "services.msc" open services.
Scroll down to "wlan auto config" right click, stop the service.
Navigate to
"C:\ProgramData\Microsoft\Wlansvc\ delete everything in this folder  leaving only a folder called "profiles" delete everything in the "profiles" folder except for a folder called "interfaces" delete everything in the "interfaces" folder)
Restart "wlan auto config" connect to your wireless network, enter
your passkey, (ensure the connect automaticly box is checked)
Restart your computer job done, your computer will now connect to your wireless network automaticly on boot.
2010-10-18T15:15:24+00:00
Hi all, I followed the above advice and thank God you guys got it just right!!! The tip from Fikin to Smokey was right on!! He said to:
I saw this very frustrating issue on both my work and home WLAN. A colleague has helped me to identify the issue and the fix we used is posted below;
  1. Go to the folder C:\ProgramData\Microsoft\Wlansvc\Profiles (it's hidden folder so you'll have to manually type the path from the windows start bar),
  2. Give the local Administrators group full permissions;
 a) In windows explorer, right click within the folder and select properties
 b) Select the Security tab
 c) Click Edit
 d) Select the Administrators group (or if it's not there already, add it)
 e) Ensure all the permissions are ticked, with the exception of special permissions,
 f) Click OK then OK.
  1. Try adding a wireless profile again by going to Network and Sharing Centre - you should not now get the "Access Denied" message.
Hope it helps!
Nikki
This worked Great!!! p.s,  I copied and pasted the folder location instead of typing it out. This fixed it, Thank God. It was just so frustrating. Thanks all, Ben.
91 additional answers
    2012-12-04T03:00:20+00:00
    I'm suffering through this same dilemma and it all started after I installed a new SSD drive.  I spent hours tracking down the real culprit and I've also noticed some trends.  I knew right from the start that my SSD was getting into Windows long before some of my devices could catch up, but I wanted to know which devices.  Turns out that my USB bus to which my Netgear 111v2 wireless device is attached had "AMD USB filter driver" installed...Well I originally put it there, but later found out that I should let the Microsoft driver do that.   The trend I notice now is if I turn my computer on first thing in the morning it gets right into the network no problems.  As the machine is running and I decide to reboot I get back into Windows and it does not connect automatically and will display the reddish star over the grey bars.  I could hit connect right there, and get in, and also the "connect automatically" is invisible.  That was a new anomaly after doing the tweaks on this page, but it doesn't matter because if I just wait a minute or two, the connection will situate itself and connect.  I like to fiddle with technical issues and I'm finding more and more that the fiddling I do IS the issue.  I'm not saying that the same is happening to anybody on this forum, but have any of you sat and watched and perhaps timed when the connection would take place..without interaction?  My issue from the start was that my SSD was just too fast on reboot...But on initial startup, there was just enough of a delay to allow the wireless service to inch out ahead and connect.  There is an option in the Group Policy Manager settings that tells the computer not to get logged into the profile until network connection is established.  So if this issue ever got me mad, that is the route I would take to fix it.  And I'm sure there are other tweaks on arranging the load order of specific drivers, but for right now I'm not messing with it.
    2012-09-22T00:37:50+00:00
    That is so easy and intuitive compared to a checkbox that says connect automatically at boot time!  I can't wait for the new version of Windows where every options is controlled by running an external program and manipulating folder contents.  Who needs a GUI?
    Navigate to
    2012-09-09T20:46:54+00:00
    Well, of course that's the obvious thing;) No, checked and unchecked for months, lol. Just got it up auto-logging the other day again. Wasn't even trying. Took days of fooling with Windows Live, wouldn't install it, errors ect. Ran registry repair several times and deleted Windows Live folder and well, guess what;) Thank God Windows Live installed and when I rebooted, what do you know...it logged on too! The previous time (months ago) it had worked it seemed to be a permission thing??? So so frustrating;)  Thank God it's Baaack;) Oh well just a little treat I guess;) Thanks though.
