Wireless Network Will Not Connect Automatically On Boot
2010-02-12T14:42:33+00:00
I have Windows 7 Professional.  Every time I boot up I have to to click on wireless icon & enter code key to connect to net.  When I go to Network & Sharing Center, active network is showing.  When I go to Manage Wireless Networks, active network not listed.  When I try to manually add it, I fill in all data and click next, I get notice that access is denied. I have admin. rights. Have talked w/HP & router people to no avail.  Just need to find fix that will automatically connect to internet on boot without necessity of entering key code each time I boot up.  Would greatly appreciate any suggestions.
2010-10-16T12:41:36+00:00
open search, type "services.msc" open services.
Scroll down to "wlan auto config" right click, stop the service.
Navigate to
"C:\ProgramData\Microsoft\Wlansvc\ delete everything in this folder  leaving only a folder called "profiles" delete everything in the "profiles" folder except for a folder called "interfaces" delete everything in the "interfaces" folder)
Restart "wlan auto config" connect to your wireless network, enter
your passkey, (ensure the connect automaticly box is checked)
Restart your computer job done, your computer will now connect to your wireless network automaticly on boot.
2010-10-18T15:15:24+00:00
Hi all, I followed the above advice and thank God you guys got it just right!!! The tip from Fikin to Smokey was right on!! He said to:
I saw this very frustrating issue on both my work and home WLAN. A colleague has helped me to identify the issue and the fix we used is posted below;
  1. Go to the folder C:\ProgramData\Microsoft\Wlansvc\Profiles (it's hidden folder so you'll have to manually type the path from the windows start bar),
  2. Give the local Administrators group full permissions;
 a) In windows explorer, right click within the folder and select properties
 b) Select the Security tab
 c) Click Edit
 d) Select the Administrators group (or if it's not there already, add it)
 e) Ensure all the permissions are ticked, with the exception of special permissions,
 f) Click OK then OK.
  1. Try adding a wireless profile again by going to Network and Sharing Centre - you should not now get the "Access Denied" message.
Hope it helps!
Nikki
This worked Great!!! p.s,  I copied and pasted the folder location instead of typing it out. This fixed it, Thank God. It was just so frustrating. Thanks all, Ben.
91 additional answers
    2012-09-09T16:00:00+00:00
    Easy, just navigate to the wireless icon in the right hand side of the taskbar; and then right click your wireless network.
    Once you have completed that click on properties and then click on the next drop on bar connection and then just tick the box saying connect automatically when this network is in range this will allow it to auto connect a wireless network so you dont have to go to the trouble of continously connecting every time you log on.
    Hope this helps.
    2012-08-20T18:46:40+00:00
    I had tried all of the other more complicated fixes with no success.  I finally found these posts from Dingo123 and TrunksXV and finally fixed the problem of not being able to connect automatically to my wireless.  I uninstalled the software and drivers that came with my USB wireless device, unplugged the device, then plugged it in again and let Windows install the driver.
    It worked for my setup.  I sure wish I had come across these posts first.
    Good luck to everyone else.
    Thanks, guys.
    2012-03-25T17:05:56+00:00
    Here's what worked for me!
    I believe its a combination of two things, its either an issue within the Windows 7 Services configurations regarding WLAN Wireless, or other service not set to automatic at startup.
    The other thing is that the software which came with your wireless card or device that you've installed on Windows 7 is having a conflict with the operating systems wireless functions. The thing is after you've installed the drivers from the installation CD, you should uninstall the software after initial configuration. Or you need to allow Windows to configure the wireless card automatically.
    The main conflict is the software which came with the device
    1 . START BY UNINSTALLING THE WIRELESS CARD SOFTWARE and RESTART if that doesn't work, than its an issue with the wireless configurations of Windows 7 itself.
    Sometimes we have to be detectives to find the issue.
