Windows 7 wireless connection problem - No Wireless Connections Available
2009-10-29T01:02:56+00:00
I have just changed from Vista Home to Windows 7 Professional on my laptop. The laptop will access the internet with a wired connection only. It now indicates there are no wireless networks to join even though my is one of 50 in the area. I asked Windows to diagnose the problem but it has no suggestions.
Thank you.
2012-04-11T02:51:01+00:00
Thanks for the help!
I am now able to "see" the wireless connections but not connect when I click to access the connection.
Friends who visit with their PC's can access my home wireless after they login with the password if they are using Windows XP and/or Vista.
My Windows 7 is still an enigma!
Spent $99 and 1/2 day with Microsoft online tech support without a solution!!!!
Upgrade to Windows 7 has been a "bummer" --- may have to go back to XP or Vista if Microsoft does not provide an update fix.
Again, thanks for the assist!
SOLVED Just signed up to perhaps help the miriad of stressed people as I was. I had 5 computers connected to home network combination of Vista and XP - no network problems. Bought new laptop with Win 7. Connected fine to network.
Left laptop alone for week or so - didn't even turn it off and when I tried to start it up - no network connection possible! Could still "see" network but wireless just would continually try to connect without success. Attached a ethernet cable from router to laptop and it connects fine - just no wireless.
Messed around with aes, tkip, antivirus plus heaps of other suggestions. But the solution was to upgrade the firmware on my router. Downloaded it from tplink website and opened the routers setting webpage and uploaded the newest firmware.
There's no doubt it is a Win7 problem as the old firmware works fine with xp, vista but they don't tell you this when selling you win7 and you spend heaps of time trying to find these solutions. I didn't try system restore but this would've been my next step as the win7 did work for a couple of weeks before it went down, so it has to be some kind of update or something that conflicted with the router after previously working.
Hope this helps someone.
2012-06-17T22:23:48+00:00
While what you have listed here are some good basic things to follow, I was already doing them.  I saw my problem show up when a patch was applied to my laptop.  Originally I saw that patch being offered by the ASUS laptop update utility.  I backed it out and the problem went away.  Later I installed some Microsoft patches and the problem came back.  Here is the issue I am seeing:
When I first bring up the system the WIFI is never turned on automatically, as it is supposed to be and as it used to do prior to the patch.  I have to select the icon in the system tray, which shows the WIFI as of to turn it on.  It does so for all for about 5 seconds, just long enough to attach to the network, and then it turns itself off again!  I then have to do this a second time and that one will work.
It also turns itself off when any device changes are made to the system, such as plugging in or removing a USB flash drive.
I sometimes see it turn itself off when my screensaver has been running for a while, but it has to have been for quite a while, say at least 20 minutes.
I have completely disabled it being powered off by Windows, so it shouldn't ever be turning this off unless I tell it to.
This system has Intel My WiFi Technology in it and I saw some post about updating Intel drivers from their site fixed a similar issue, but it turns out that was for a different Intel WIFI chipset than what I have.  I have verified I am on the latest version of their drivers.
This become quite intolerable when I am at class at ITT and need to be on the network using my WIFI connection.
I am open to any suggestions.  Right now it seems my only option is to backout the last set of patches from Microsoft, because I don't know just which one causes the problem, and ignore all other patches that are made available.  That is not a good solution, because it means I will be ignoring possible security and bug fixes that I actually do need.
Mike
Hello Everyone,
I wanted to thank you all for the active discussion in this thread, and I would like to jump in and see if I can help address the multiple issues that seem to be covered in here.   I would also like to take the opportunity to thank Barb Bowman (MVP) for their efforts in this thread to date 
For a full list of steps to try, see the Wired and Wireless Tutorial on this page:
http://windows.microsoft.com/en-US/windows/help/wired-and-wireless-network-connection-problems-in-windows
After reading through the thread, there appears to be some confusion regarding Wireless Networking technologies and configurations using Windows 7 and I would like to spend some time to try and clear things up with some basic troubleshooting / best practices for Wireless Network related issues.
1.       First try and power off your modem, router and desktop/laptop. Then power on the modem, then the router, and then finally the desktop/laptop. Please do this in that order, allowing 60 seconds in between each device to enable the device to be fully booted and able to accept connections.
2.       Update the drivers for your wireless network adapter via Windows Update, or by using the website for either the company you bought your PC/Laptop from or the manufacturer of your networking device.
3.       Ensure that your router is set to broadcast it’s network name (SSID), ensure that you are connecting to the correct wireless network (SSID) and that you are using the correct WEP/WPA  passkey on both devices.
a.       Please use “Windows Connect Now” or “Wi-Fi Protected Setup” if available on your wireless router to ensure that the connection is setup correctly.
4.       If you are trying to use WPA or WPA2, please ensure that both your network adapter and wireless router support this protocol. If you are having issues detecting your wireless network when using WPA or WPA2, try configuring your router to use WEP instead and see if you can connect.
a.       Please note that the change between WEP/WPA/WPA2 will need to be made on both your computer and wireless router.
b.      If you are only able to connect using WEP, then your networking hardware may need a firmware upgrade. If you are not comfortable doing this yourself, please call your hardware/router manufacturer for help in doing this.
5.       If you are having a problem with your wireless connection after resuming from hibernate or sleep, or are having intermittent connectivity issues, try to adjust your Power Management profile to change your Wireless Adapter Settings to Maximum Performance.
a.       To do this click “Change Plan Settings” next to your Power Profile, and choose “Wireless Adapter Settings” and set it to Maximum Performance. You should do this with all of your power profiles. Additional guidance is available here: http://windows.microsoft.com/en-us/windows7/products/features/power-management
6.       Call the support line for your router manufacturer. It is likely that neither Windows nor the router are having problems, it is simply an issue of getting the configuration settings on both set up to work correctly together. The router manufacturer will be the best resource to know how to configure their device.  Most of the contact numbers are listed here: http://support.microsoft.com/gp/vendors/en-us
For more information please see the following links:
http://windows.microsoft.com/en-us/windows7/Why-can-t-I-connect-to-a-network
http://windows.microsoft.com/en-us/windows7/set-up-a-wireless-router
http://windows.microsoft.com/en-us/windows7/Add-a-device-or-computer-to-a-network
http://windows.microsoft.com/en-us/windows7/Wireless-networking-frequently-asked-questions
I will continue to monitor this thread but will likely end up splitting this thread into individual smaller threads to address the various different issues that have been mentioned so far.
If anyone has any questions please let me know.
Kevin
If you find that my answer was what you were looking for, please remember to click the "mark as answer" box below!
2010-04-24T00:42:02+00:00
Hello Everyone,
http://windows.microsoft.com/en-US/windows/help/wired-and-wireless-network-connection-problems-in-windows After reading through the thread, there appears to be some confusion regarding Wireless Networking technologies and configurations using Windows 7 and I would like to spend some time to try and clear things up with some basic troubleshooting / best practices for Wireless Network related issues.
Kevin
507 additional answers
    2011-01-05T18:47:47+00:00
    I think I'm going to puke!!! Not because all of the sudden my Brand new (2 months old) laptop can NOT find any wireless networks including the one I set up long before this laptop and had never ever had any issues with any PC here at home including this new Toshiba until NOW ...
    The reason I feel like puking is within the last years all the stuff I have been talking about for the last 10 years involving BIG CORP AMERICA has painfully been confirmed. I have now been the victim of 3 major Corps starting with HP. Early 2003 I  bought a top of the line HP pavillion laptop to the tune of $1800, within 3 months it was back to HP for a new motherboard .Thinking this is kind of rare but i guess someone has to get 1 of at least 10,000 PC's that just have manufacture defects or whatever (legitimate problem). Now i am going to spare you all the time i spent on the phone, e-mails and not to mention the additional $ spent to have the product it was supposed to be, actually be. Bottom line is I spent 3 times as much $ as I originally paid for it new. HP and other repair facilities actually had it more than I did. When it had its last issue in Sept 2010 and i had really started researching the solution myself, I found out that HP knew of the certain issues that these pavillions had before they mass produced them and sold them, and continued to sell them for an additional 3 years without implementing the 50 cent per unit fix. Realizing if they coped to the now wide spread issue not only would they be loosing maximum profit from all of the units manufactured after the fix but then they would have to do a recall or something to deal with all they sold before the fix as well. Big Corp solution you asked? Simple !! First is deny knowing of any common mass issue. Second occasionally miss direct by blaming manufactures of components they installed as a HP product. And then there is my favorite most widely used by all big Corps !!  Third make technical support so frustrating and time consuming and non existent that most just give up and buy something else new.
    Which brings me to the current issue and Microsoft.  After my little mishap and imaginary problem with HP, I was left with still needing a laptop! Ok, No big deal, right? I'll just run down to fry's and stay away from HP and buy something simple and fairly inexpensive due to the fact that you don't always get what you pay for  at least with HP. So I'm at fry's and looking around find a few that appear to be worth the financial risk again...LOL.... but notice that every single PC they had in that store only had windows 7. Using benefit of the doubt and ASSUMING that Microsoft had surely worked the bugs out of this OS after their embarrassing release of Windows ME followed by their all new and improved Vista disaster. So I purchased the Toshiba mentioned earlier. Got it home unpacked it, set it up first to the Lan (Eithernet) connection then right to my WAN Wifi connection using WPA 2 security Poof No Problem. Start using it quit often but not really noticing the wonderful features the according to Microsoft you and I built into Windows 7. Then running into compatibility issues, followed by ie just completely disappearing, Mozilla crashing, the inability to get very basic needed software to run right and consistently like Adobe and Winzip. I was beginning to get really frustrated and disappointed. So to put my mind at ease I Google Toshiba and find virtually nothing to send up a flag, Google Win 7 32 bit and really don't find anything to serious mostly just have to  wait for patches or upgrades, expected from a new OS like WIN 7. Meantime I get ie ironed out Winzip, Adobe and Mozilla all working and consistently,  I'm ok with this new Toshiba and Win 7 will top XP eventually. Well that lasted roughly a month and a half!!!Which brings me to the current manufacture defect that the manufacture is actively exercising the BIG Corp 1,2,3 solutions mentioned above from HP!!!
    Heres the kicker!! Which brings me to Apple i touch. I bought me a lil music, video, full blown browser n internet capabilities in the palm of my hand for a lil under $300. Bought this Dec 22 2010..... 2 days before this Win 7 manufacture known issue I have discovered that the ipod has  issues with Safari the chosen internet browser developed by Apple and until recently a MAC/ Apple exclusive internet browser, just crashes or wont find Wifi and run any apps. How did I found out that Apple has known about this problem for over 2 years now?  Googled my issue to find I am one of hundreds of thousands of people with this same issue!!!
    Anybody noticing a common thing here?  Look their to big for any one of us to do any reputable damage to, we no longer band together on things (the last time we did was the civil war) and the Icing on top of the cake is these Corps have learned how to screw us constantly from no other than our Federal Government!!  ya i know some of you are going to say "WOW" this guy is way off of the subject of this thread or "He's blaming the Government for his bad experiences"
    Look it's how it is no matter how you try to justify it... they ALL make ____ knowingly, over charge us and then basically try to make us feel we are stupid or some how or some way its our fault, that we are having a new isolated issue that we must have caused by some how opening the wrong end of the box!!!!!
    Anyways I cant wait for the person that is going to find the cure for all of us because THE bottom line is!!! It's a WINDOWS 7 issue!!!!
  2. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2011-01-05T16:35:58+00:00
    specifically, did you go into device manager, expand the devices, locate the
    wireless, right click, properties and on power saving make sure that allow the
    computer to turn this device off to save power was NOT checked?
    On Wed, 5 Jan 2011 15:15:17 +0000, Garlum wrote:
    >I have disabled many of the power saving features
    Barb Bowman
    http://www.digitalmediaphile.com
