XBOX 360 wireless receiver won't connect to controller with Windows 7 64bit
2010-02-23T03:37:19+00:00
Hello, im having a problem with a xbox 360 wireless receiver on my windows 7 64bit, i installed the software that came with the receiver and it installed fine but when i went to connect the controller with the receiver it doesnt work, i've tried it dozens of times and i have rang microsoft for help but they werent too sure. Its a official controller which came with an xbox360 and the receiver isnt microsoft but i was told from the microsoft people that some receivers are made outside of microsoft but are still fine. I'm wondering if there is a specific windows 7 receiver driver for it?
thanks
james
Windows for home | Previous Windows versions | Gaming
2010-03-02T12:27:51+00:00
hey thanks i got it to work! so relieved. heres how you do it:
Right click on Computer
Go to Properties
Click on Device Manager
Right click on the Unidentified Device
Go to Properties
Go to the Drive tab
Click on Update Driver…
Browse my computer for driver software
Let me pick from a list of device drivers on my computer
Microsoft Common Controller for Window Class
Xbox 360 Wireless Receiver for Windows Version: 2.1.0.1349 [8/13/2009]
Update Driver Warning
Click Yes
i cant believe it was that simple, you dont need to download any seperate driver or anything, just follow the steps.
thanks
151 additional answers
    2013-10-22T18:22:38+00:00
    my god man you genious
    2013-10-19T22:18:00+00:00
    WORKS GREAT! I was having trouble with Windows 8.1 and this did the trick. If you're on Windows 8.1, the device category will be "xbox peripherals". Thanks!!!
    2013-10-17T17:18:14+00:00
    Simple? I've been trying to make this work for 4 hours now. Simple my @ss man.
    Microsoft you suck! SUCK!
    2013-10-05T00:28:17+00:00
    Go to Properties
    Go to Properties
    Go to the Drive tab
    Click Yes
    Right there, the bold text. That is where I run into problems, because it isn't there. You see how annoying that is? Is like trying to find something that doesn't exist. Oh wait it is, pardon my frustration but I've been trying to find a solution for this for the past hour and nothing works. I've tried like 5 different methods and downloaded different drivers to no avail.
    This is really annoying.
