XBOX 360 wireless receiver won't connect to controller with Windows 7 64bit
2010-02-23T03:37:19+00:00
Hello, im having a problem with a xbox 360 wireless receiver on my windows 7 64bit, i installed the software that came with the receiver and it installed fine but when i went to connect the controller with the receiver it doesnt work, i've tried it dozens of times and i have rang microsoft for help but they werent too sure. Its a official controller which came with an xbox360 and the receiver isnt microsoft but i was told from the microsoft people that some receivers are made outside of microsoft but are still fine. I'm wondering if there is a specific windows 7 receiver driver for it?
thanks
james
Windows for home | Previous Windows versions | Gaming
2010-03-02T12:27:51+00:00
hey thanks i got it to work! so relieved. heres how you do it:
Right click on Computer
Go to Properties
Click on Device Manager
Right click on the Unidentified Device
Go to Properties
Go to the Drive tab
Click on Update Driver…
Browse my computer for driver software
Let me pick from a list of device drivers on my computer
Microsoft Common Controller for Window Class
Xbox 360 Wireless Receiver for Windows Version: 2.1.0.1349 [8/13/2009]
Update Driver Warning
Click Yes
i cant believe it was that simple, you dont need to download any seperate driver or anything, just follow the steps.
thanks
151 additional answers
    2013-08-24T00:50:29+00:00
    i love you thanks lol was messing with it for days and found this gem of a post!
    2013-08-12T13:17:06+00:00
    And what do you do if that isn't solving the problem?
    2013-08-09T19:45:58+00:00
    it shouldn't be this hard to get done if the solution is so simple! THANK you so much!
    2013-08-07T23:15:30+00:00
    I already did the driver manual install and the controller synced and was working perfectly.
    Then I had the great idea to sync it to my xbox360 again...
    After that I can`t get it to sync to the wireless receiver again...
    After plugging with the charge kit it ended up unsyncing from xbox, but when I try to sync with the receiver the led keeps moving and the receiver blinking, but they dont sync up....
    Any ideas?
    PS:I tried unstalling drivers and software and doing it again but it didnt work...
