Edge will not close - any help please?
2025-05-17T09:07:34+00:00
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
Microsoft Edge | Other | Windows 10
    2025-05-20T11:43:22+00:00
    1 Click three dots at top right
    2 Click settings
    3 Click System and performance
    4 Click System
    Turn off the all and restart browser
    Thanks its worked for me
    2025-05-20T09:51:32+00:00
    Thanks Larry it s working for me
    2025-05-20T02:23:58+00:00
    thanks for post.
    turning off "use graphics acceleration when available" is what fixed it for me
    2025-05-19T22:22:43+00:00
    Larry you are awesome
  5. Deleted
