Other issues or features related to Microsoft Edge on Windows 10
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
This issue started happening after Microsoft ran a software update. The update occurred about 3 days ago, I think
whilst the so called fix also worked for me - you have defo hit the nail on the head. We shouldn t be messing about in settings in order for Edge to behave itself.
same issue ,went to installed apps /edge/ 3 dots/ modify/fix /worked it for me
Because its a junk browser. Its in the coding its screwed up. I disabled Edge in the registry
Edge isn't my primary browser, so all those settings have always been off by default. I've also tried going into windows settings and doing the modify/repair method which also doesn't work. I'm now in the boat that this is a windows update related issue.
