Other issues or features related to Microsoft Edge on Windows 10
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
I tried that, but left the "use graphics acceleration..." turned on. I restarted my PC, then opened Edge (and resored the tabs when prompted), but it still wouldn't close, so I just now turned that one off as well, restarted Edge and it closes properly now. So at least in my case, I think it was the "graphics acceration" setting (but I don't have time to turn the others back on to test that out).
Thanks!
Thank you, Larry. This worked for me too.
Same here. My wife's computer is doing it too.
This worked!
Hey Kimberly, I just wanted to see if you did both the settings and the CMD lines or did you just change the settings?
