Other issues or features related to Microsoft Edge on Windows 11
Edge has been updated and it's causing issues with highlighting and copy/paste from a web form field. I tested this on 3 different PCs. The issue presents itself with Edge version: Version 131.0.2903.51 (Official build) (64-bit). 2 of my PCs were updated to that version and do not work. The PC that is still on the older version of Edge 130.0.2849.80 (Official build) (64-bit) still works. Rolled a browser on a PC having the issue back to Edge 130.0.2849.80 and the problem went away. Anyon else having this issue?
The issue does periodically popup with new builds of Edge. As a workaround I downloaded Edge beta which is on a different build since we had an application that required the use of Edge.
