Stop Edge from taking control of PDF's permanently!!!
2021-01-20T05:56:56+00:00
I am very frustrated with Microsoft Edge continuously hijacking PDFs.  I run Adobe Acrobat and need to have the tools.  I have tried the standard ways of setting Adobe as the default program for PDFs - through Control Panel, through Properties of the file, through Open with.  None of these work for even an hour.
I have also tried a couple of hacks through Regedit that seem to work for others but not for me.
I am at the stage that if i could I would uninstall Edge.
So, how can I permanently set Adobe as the default program for PDFs?
Microsoft Edge | Read PDFs | Windows 10
    2021-10-08T10:08:15+00:00
    there is only one way to solve this, enter regedit and turn off the file in edge. google it
    2021-06-30T11:44:16+00:00
    Hi Todd
    I feel for you. I am lucky in that a full reformat (Win 10 Pro) solved the problem. I found no comfort or solutions from either Microsoft or Adobe. I would have thought that it is in their best interests to solve this as there are alternatives to both Windows and Adobe.
    I wish you all the luck and maybe Windows 11 will be more reasonable.
    Cheers
    Lester
