Managing tabs, address bar, and search settings in Edge on older Windows versions
I used to have tabs/sidebar on far right, now I do not!
How can I repair EDGE, or what needs to be repaired?
Thanks!
CarrmasDad
Is it possible to enlarge the DARK words etc.
and change the size and tint of the light words etc.?
I answered a similar question a couple of weeks ago: Making all text on Edge webpage darker - Microsoft Community
You might find the solution useful.
I opened Settings but I did not see APPEARANCE!
The settings navigation pane is hidden if the window is too narrow. You should see a 'hamburger' icon ≡ to the left of the Settings heading; a click on it should then reveal the settings menu. Or just make the window a bit wider.
Hi CarrmasDad,
They must have different settings in the Windows 7 edition, if you click the 3 dots at the top right of Edge, on the resulting menu, near the bottom, is there the 'Show Sidebar' option on that menu?
Hi Dave,
I really appreciate your help, and you are so right about the limits on EDGE!
i DO NOT WANT YOU MAD AT ME!
CarrmasDad2
