Sidebar tabs on right side, are missing in EDGE!
2022-10-02T16:08:51+00:00
I used to have tabs/sidebar on far right, now I do not!
How can I repair EDGE, or what needs to be repaired?
Thanks!
CarrmasDad
Microsoft Edge | Tabs, address bar, and search | Previous Windows versions
2022-10-05T07:59:55+00:00
Is it possible to enlarge the DARK words etc.
and change the size and tint of the light words etc.?
I answered a similar question a couple of weeks ago: Making all text on Edge webpage darker - Microsoft Community
You might find the solution useful.
2022-10-02T18:34:15+00:00
I opened Settings but I did not see APPEARANCE!
The settings navigation pane is hidden if the window is too narrow. You should see a 'hamburger' icon to the left of the Settings heading; a click on it should then reveal the settings menu. Or just make the window a bit wider.
DaveM121 929K Reputation points Independent Advisor
2022-10-02T17:32:59+00:00
Hi CarrmasDad,
They must have different settings in the Windows 7 edition, if you click the 3 dots at the top right of Edge, on the resulting menu, near the bottom, is there the 'Show Sidebar' option on that menu?
13 additional answers
    2022-10-09T14:36:19+00:00
    Hi Dave,
    Sorry for not getting back to you sooner!
    Please look at the following!
    AFTER CLICKING CUSTOMIZE FONTS I got the following! What do you recommend I use? Where do I find a way to darken the fonts?
    Many Thanks! CarrmasDad2
    2022-10-06T20:04:16+00:00
    Hi Dave,
    I have not gone past the clip so far, sure do not want to mess up!
    Appreciate you!
    CarrmasDad2
