FIX: Insiders not able to switch channels - **UPDATED 8/3/2021**
2021-08-02T18:50:42+00:00
Hello Windows Insiders!
Windows 11 is now in the Beta Channel, and some of you are wanting to move over from the Dev Channel. We've been getting some reports that some of you are not seeing the options to change in Settings > Windows Update > Windows Insider Program. We have a fix that should get you back on track. Please note, this fix is for devices that are not showing the Choose your Insider Settings and Windows Insider account settings, as in the image below.
If you are seeing this, please follow the steps below to restore the missing options:
  1. If you have Bitlocker enabled, please suspend it.
  2. Click Start
  3. In the search box, type cmd
  4. In the lower right of the search results, under Command Prompt, click Run as Administrator
  5. On the UAC prompt, click OK
  6. At the elevated command prompt, type: bcdedit /set flightsigning on
  7. Press Enter
  8. At the elevated command prompt, type: bcdedit /set {bootmgr} flightsigning on
  9. Press Enter
  10. Reboot the device
You should now see the missing options:
If performing these steps to not resolve your issue, please file a new feedback item in Feedback Hub, so we can investigate.
Thank you!
-The Windows Insider Team
  1. Johnny55 5,155 Reputation points Volunteer Moderator
    2021-09-06T15:46:39+00:00
    By The Way, it has been more than 10 days since I downloaded Windows 11, and don't want to go back to windows 10 and etc. if there is any fix to this problem please let me know
    at first, downloading windows 11 I used the dev channel then later changed it to beta, the 22000 updates switched back my choice from beta to dev I have no idea why this happened.
    so please let me if there is anything I can do. that doesn't involve me doing a clean reset of the device and start the progress of downloading windows 11 from the beginning
    Hello RNG,
    When you switched to Dev, you ended up doing what we call a major upgrade, rather than the CU updates in Beta. Dev channel (which is not tied to any specific build) is now running version 22xx. Beta is running version 21H2, they are entirely different versions. Thus your options are greyed out. If you go to Settings, Update, Recovery, you will see an option to roll back to previous version, which would be Beta. You have 10 days from installing the Dev build to do so. Then ensure your Insider Settings is set to Beta.
    As per previous pic you posted, it displays 22449 which is a Dev build. The only way back to 22000.xxx you have some time left to roll back. Dev channel is now a point of no return to Release for over a year minimum. If you ran disk cleanup and deleted the windows.old folder, you will not be capable of rolling back. Here your only option is to clean install. Doing a reset keeps your current version so that will not work.
    This is why MS has been sending out several emails notifying Insiders on Dev channel to switch to Beta channel while you still had the opportunity to do so. Once on the new build of 22449 you have moved on to future builds. This is not next months Release version that you are currently running.
    Bottom line, if you cannot roll back, you have to start fresh using the ISO for Beta or remain in Dev for another year.
    2021-09-06T11:38:27+00:00
    2021-09-06T11:29:00+00:00
    After I roll back will I still get updates on the beta version, and is there any chance of my data corrupting??
    2021-09-06T09:33:35+00:00
    I've used the commands at the elevated command prompt twice. No change. I see the three options. Dev, Beta, and Release Channel. The problem, as I've stated, is that it is fixed in Dev and the other options are not selectable (greyed out, no-op, etc. I cannot choose my level of participation to Beta as I want to.
    I've done the regedits you suggested, changed them to Beta, rebooted and they came right back up as Dev. Is there a way for the Insider Program to change my level of participation using my login info since due to a bug I cannot?
    I can ignore dev builds (like the one pending) but how do I get security updates? You can't choose which item available in WUS you want to download - it's all or nothing. That needs to be fixed also.
    2021-09-06T06:44:45+00:00
    ХОЧ МАШИНИ НЕ ВІДПОВІДАЮТЬ МІН. ВИМОГАМ БІЛЛА, ТАК І ЗРОБИВ, ПОТІМ ПРОГОЮ ВІД БІЛЛА ВРУЧНУ ПЕРЕМКНУВ НА BETA. 3 ДНІ, ПОЛЬОТ НОРМАЛЬНИЙ, КРІМ ТОГО, ЩО ПРИЙШЛОСЬ ЗАНОВО ПЕРЕУСТАНОВЛЮВАТИ ВСІ ПРОГРПМИ ТА ДОДАТКИ.
