Not working, nothing shows up!!!!!!
这个需要在设置开启发送可选数据
Hello Windows Insiders!
Windows 11 is now in the Beta Channel, and some of you are wanting to move over from the Dev Channel. We've been getting some reports that some of you are not seeing the options to change in Settings > Windows Update > Windows Insider Program. We have a fix that should get you back on track. Please note, this fix is for devices that are not showing the Choose your Insider Settings and Windows Insider account settings, as in the image below.
If you are seeing this, please follow the steps below to restore the missing options:
You should now see the missing options:
If performing these steps to not resolve your issue, please file a new feedback item in Feedback Hub, so we can investigate.
Thank you!
-The Windows Insider Team
не працює. Чи є інші шляхи переходу на Dev Channel? крім чистої інсталяціїї. доречі, вона теж не працює
