FIX: Insiders not able to switch channels - **UPDATED 8/3/2021**
2021-08-02T18:50:42+00:00
Hello Windows Insiders!
Windows 11 is now in the Beta Channel, and some of you are wanting to move over from the Dev Channel. We've been getting some reports that some of you are not seeing the options to change in Settings > Windows Update > Windows Insider Program. We have a fix that should get you back on track. Please note, this fix is for devices that are not showing the Choose your Insider Settings and Windows Insider account settings, as in the image below.
If you are seeing this, please follow the steps below to restore the missing options:
  1. If you have Bitlocker enabled, please suspend it.
  2. Click Start
  3. In the search box, type cmd
  4. In the lower right of the search results, under Command Prompt, click Run as Administrator
  5. On the UAC prompt, click OK
  6. At the elevated command prompt, type: bcdedit /set flightsigning on
  7. Press Enter
  8. At the elevated command prompt, type: bcdedit /set {bootmgr} flightsigning on
  9. Press Enter
  10. Reboot the device
You should now see the missing options:
If performing these steps to not resolve your issue, please file a new feedback item in Feedback Hub, so we can investigate.
Thank you!
-The Windows Insider Team
    2021-08-20T18:50:44+00:00
    У меня вообще на 21H2 не получается запустить программу предварительной оценки. В реестре настройки телеметрии установлены правильные (на "3"), но ползунок недоступен.
    (It's 'Improve Handwriting Recognition', and something gone wrong)
    2021-08-20T13:45:42+00:00
    I found a bit different issue in my insider program. I am in the beta channel now. When I checked the insider program choices, it was unable to change from beta channel to release preview channel (that grey out). Is it by design? The option above was not working in my case. Thank youImage
    Release Preview is currently only for Windows 10. Since you are running Windows 11 currently, Release Preview is not an available option. This is by design.
    -Eddie
    2021-08-20T13:15:10+00:00
    2021-08-20T13:13:21+00:00
    this dont work for me, did try this 2 times, only dev.. cant pick anything. opt out but still in que. 2 month in que
    If you are seeing the Dev channel as an option, but Beta is greyed out, that is by design. It means your device does not meet the hardware requirements. You will need to perform a clean install of Windows 10 build 19043.
    -Eddie
  5. Deleted
