For mainstream support x64 on ARM64 is coming with Windows 11 -
ARM64 Office is available for those running Insider Windows 11 and Insider Office -
64-Bit Office for Windows on ARM
I'm running both on my Surface Pro X as of yesterday.
Hi Jeff.
once you haveWin 11, how about other software that did not run under previous emulator? Java 11 64bit apps with native a native architecture modules (PMOD, Romexis etc.), Mathematica of Wolfram...
MarcinB.
Sorry, I avoid Java Apps and IDEs like the plague. See my other post about running Mathematica, it ran fine, the install was slow but the application ran. Killed the battery quickly though.
I still don't understand why running ML and Analytic Creation apps on a tablet is something, I have a Developer Machine in Azure that has the horsepower needed to do my heavy lifting. The LTE let's me connect to it whenever I need it.
Hi. I entered Insider with Windows 11 (now build 10.0.22000.65) and I got Java 11 64-bit based application which has some x64 specific code and it run fine. I installed Mathematica 12.3.1 and surprisingly the kernel app work fine, but the main interface crashes at welcome screen. The error 1000 in Event Viewer is in Windows system file xtajit64.dll in system32 folder. I do not find to what this dll is related.
- Can you still run Mathematica in current insider build of Windows 11?
- Which version of Mathematica you tried, and it worked in Surface Pro X?
Thank you in advance.
MarcinB.
