2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-03-24T16:20:23+00:00
    Don't put any pdf files on Onedrive, or uncheck the PDF extension checkbox in the Advanced window of Indexing Options.
    -M
    This is a known, but separate issue. To fix the problem with the Windows indexing service causing high CPU usage due to PDF files, you can download Adobe's 64-bit PDF iFilter driver from here:
    Adobe PDF iFilter 64 11.0.01
    2015-03-24T11:32:04+00:00
    -M
