2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-03-24T11:10:21+00:00
    I think it could be related to OneDrive and syncing.  I had this problem on my HP Laptop, which is why I bought the SP3, which is doing the same thing.  Is your problem related to background syncing to OneDrive by any chance?
    2015-03-21T19:16:01+00:00
    Rather than disable the High Definition Audio - I uninstalled the driver AND checked "Delete the driver software for this device." The default sound (High Definition Audio Device) driver will be installed (reboot or scan for hardware changes)."
    Result: Basic audio from the SP3 without the high CPU.
    REMEMBER this hardware device will prompt for Windows Update install. Will have to ignore that install (not sure if will install automatically if updates set that way on your machine) until the driver is fixed.
    Hope this helps.
