2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-12-01T17:29:47+00:00
    Coming up to 7 pages for this thread, and the folks at Microsoft seem to be completely asleep at the wheel. I've kept my SP3, but only because even with this defect it's infinitely better than the POS Dell I'd be saddled with otherwise (work machine). I've been lucky, I suppose that unlike some others, I don't experience the issue when waking from hibernation; it only happens when waking from sleep. As a result, I've been able to manage the issue by simply never letting the SP3 sleep, and forcing it to always hibernate instead. However, that also means that when I'm ready to use the SP3, I have to wait minutes for it to wake up instead of seconds, which is a total drag.
    I'm not even sure if anyone from Microsoft is still following this thread, but in the faint hopes they are, please, please, please for the love of everything good and holy in the world, at the very least, acknowledge the issue and look into it. The silent treatment you're giving your customers here is really bad form.
    2014-11-30T09:36:57+00:00
    Lufthansa and Austrian Airlines are planning to use 5000 Surface pro 3 for their pilots.
    Scenario:
    After booting the suface the pilot will feel the surface getting hot. He decides to reboot. It will take 3 minutes. Not very much time? 5000 pilots are using Surface pro 3: 5000 times 3 minutes rebooting are 250 hours waiting time for the passengers.
    GOOD LUCK Lufthansa and Austrian Airlines!
