2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-11-26T22:49:33+00:00
    Spoke with the Microsoft on-line support about that issue. That said that they are not aware (!) of this problem. It's a shame! Half a year and there is still no fix!
    M$ are trying to ignore the issue is even there. Custom support just gave me the usual "Do a full reset/restore of the system, re-download updates blah blah" time after time. It's absolutely shocking how they are handing this MAJOR this issue.
    I started this thread and I found the solution which I recommend to everyone, it's quite simple to:
    I sold my SP3 on eBay, problem solved - No more CPU high idle and will not buy other Surface ever again!
    2014-11-26T21:55:48+00:00
