2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-10-09T12:57:08+00:00
    Hi Luis,
    I encountered the same Problem. Same Setup as you have.
    The Surface Pro 3 (i5) is connected with a 27" Dell Monitor. The Monitor has a USB Hub integrated. Keyboard, Mouse and Ehternet adabter are connected to the Monitor USB Hub.
    Disconnecting the hub from the Surface stops the high System interreupts.
    Do you find any solution in the meantime?
    2014-10-07T13:31:42+00:00
    Anybody have a sollution yet?
    We just bought a couple of surfade pro 3s and we have the same problem with all of them. CPU load is constant at around 20% when cold booting. I have a sdcard inserted.
