2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-10-01T00:23:39+00:00
    Thanks for feedback, I was generally aware of the situation, I posted so as to keep the subject going. It is a problem which MS need to address. I have 16gb MSD card installed with a swag of songs on it, removed & the device appears to have quietened down, I will observe it for a few days and I will most probably re-insert. I am not overly concerned, as long as I have a handle of what is going on. No real overheating problems, the device runs nearly 24/7.
    Great device, it may finish up being my main device, being retired now, my computing demands are not so high.
    2014-09-30T21:16:55+00:00
    This is a known problem that has existed in SP 2 as well. With these processes running like that your system will overheat soon. More on it here: http://answers.microsoft.com/en-us/surface/forum/surfpro3-surfusingpro/surface-pro-3-high-cpu-load-when-idle-high-sysytem/d17d1332-3c00-402d-9f15-fecee27d1c45
