Surface Dock 2 Display Problem
2020-06-05T14:16:32+00:00
Dear Microsoft-Team,
Dear Community,
I recently got the brand-new Surface Dock 2 for my home office. I try connecting it with my Surface Pro 7 and a Samsung C34J791 (LC34J791WTUXEN) monitor with the supplies USB-C cable from Samsung which came with the monitor.
Windows is recognising the monitor fine, it shows up in the screen settings.
But the display is not showing any images, it just keeps switching through the inputs to find a proper signal and after some time the monitor goes into sleep mode as it could not find a signal.
If I now connect the display to the Surface Pro 7 directly with the same cable it works just fine and I can see the desktop on the Samsung monitor.
What do you suggest?
Thanks a lot in advance for your kind assistance and have a great weekend!
Best regards,
Julian
    2020-11-03T14:25:43+00:00
    Same issue here, New MS surface Pro 7, MS Pro Dock2, Dell U4919DW.
    When I restart the computer I always need to reboot the display.
    I always have to start computer then connect the Dock2 to get display to work.
    Also sometimes screen gets blurry and need to reboot to solve.
    Have lots off issues with our customer and dual displays not always starting on the dock.
    I see lots of threads with people having problems but no real solution.
    Our company has desided not to use Dock2 opting for Dell 6000 universal.
    This is all hi-end stuff that needs to work.
    2020-11-01T19:48:43+00:00
    Same problem here. Surface Pro 6/Samsung C34J79/Dock 2/USB-C to USB-C. Surface identifies the external display but no image on screen
    2020-10-14T14:54:41+00:00
    Similar issue here appears to be solved.
    Surface Pro 7, Surface Dock 2, USB-C to HDMI on 4k TV.
    Extended monitors works perfectly when I use the USB-C port on the Surface to connect to the TV, but not through the display port on the dock,
    I had Windows check for updates and installed until it displayed "Up to date"
    Then installed the latest Dock 2 firmware for Surface Pro 7 here:
    ---- https://www.microsoft.com/en-us/download/details.aspx?id=101317
    Unplugged everything, restarted, plugged dock charger and monitor back in and it looks like it worked.
    Hope this helps
    2020-10-14T10:54:55+00:00
    I have the same issue. Clearly it is a widespread fault.
    Surface Pro 7, Surface Dock 2, USB C to HDMI
    Initially it works then if the surface goes to sleep and you log back in it will not send signal to the external monitor. You can see that the desktop is still extended (i.e. all the apps and start bar are being sent to the monitor that is black), but you can't get to it.
    I have tried the SEMM drivers - nothing
    Unplugging cable and replugging - nothing
    Remove power to the dock and plug back in - all comes back to life.
    Same cable directly from Surface to Monitor - works most of the time.
    MS need to provide a proper solution here. These docks are expensive. This is unacceptable level of problems.
    I feel the same i am having constant issues with my Surfacebook 3 and this dock will not power my two screens it's advertised as duel 4k display I've done everything sometimes it works sometimes it doesn't i can't even return the thing now as i have had it for 30 days.
    Microsoft need to do something as I've paid a lot for this device for it not to work!
    2020-09-30T14:37:37+00:00
    Hi everyone,
    Same problem here. Brand new Surface Book 3, full options, with Surface Dock 2. What a shame... Really hoping and expecting to get a viable solution soon. I'm aware this post won't help technically but it may help by putting pressure on Microsoft.
    All the best to all of you,
    Simon
