I've got similar problems, and I am now on my 2nd Pro 7 i7 in 6 months.
With the first one the problems got so bad I went to a Microsoft store, explained the issue(s) and showed lots of video and got a new one after they determined that it's a HW problem.
The new one was (kind of) doing fine in the beginning, but the problem is back and appears both with USB-C and the dock which I prefer to use. I was hoping to have 2 external monitors but that even intensified the problem.
I only use DisplayPort connections, the cables are brand new and came with the Monitors. The 4k monitor (my preferred one) is LG Ultra HD.
As this problem starts to impact my productivity more and more, I wonder if I should return the Pro 7 and use a different brand. It's too bad as I used a Pro4 for 3 years before and that was the best computer I ever had.
Please help
Theo Gees
Hi Theo. So...my recent experience is that I have tried about all the things I can think of. The only thing left is to update or replace the video driver. I am going to get my techo guys do that once I am out of lockdown.
Having said that...this is what I find. If the 2nd screen starts flickering, going fuzzy or similar, I turn it off wait about 20 seconds and turn it back on. I have to do this maybe 3 or 4 times. Sometimes I have to leave it off for a while (say and hour). Sometimes to reboot the laptop. I have not found a pattern but then, just as 'randomly', the 2nd screen starts working and will stay working for a couple of days. When this happens I dont turn anything off, I just let the screen saver do its thing and allow the 2nd monitor to sleep.
I am using the docketing station. I have tried the USBC connector but without any improvement.
Like you, I really like the surface but Microsoft really have dropped the ball on this issue.
David
