WiFi/Networking issue when connected to docking station
2015-12-16T10:29:24+00:00
I recently bought the new Surface Pro 4 (i7, 512 GB SSD) along with the new docking station. I've experienced some of the general issues that various other people have mentioned (such as the power management/sleep issue) but I'm also seeing an issue that does not yet seem reported.
When I have the new docking station connected, if it's connected to a monitor, the network connectivity sometimes drops. I have been using it without any issues for about 2 weeks, but today I had a lot of trouble connecting to the office WiFi network. The network itself was definitely working properly as it was quick and reliable for several other users, including my own phone. Nonetheless, I rebooted the router to make sure.
Windows simply would not connect to the WiFi network (even though it has always been a saved connection). Trying to connect caused it to sometimes fail and sometimes ask for the network password (and entering it correctly would still fail - but that's another long-standing Windows bug!). Connecting to alternative networks did exactly the same; it would attempt to connect to my phone's portable hotspot, connect and disconnect in a few seconds, retry, and then stop (in a disconnected state). Intermittently it would connect to the network, but sometimes with 'No Internet' and clearly lots of DNS issues in trying to resolve google.com. It sometimes took 30-60 seconds to load google.com.
Troubleshooting steps
  • Tried disabling and re-enabling the WiFi adapter
  • Tried restarting Windows 10
  • Tried disabling all other network adapters (the Ethernet port from the dock and two created by VirtualBox)
  • Tried removing dock connection
    • This is the first time the connection issues were resolved and google.com was loaded (and could be reloaded) within milliseconds
  • Re-attached dock and tried removing Logitech unifying receiver (the only USB device plugged in)
  • Tried removing monitor
    • Everything back to normal, was able to browse very quickly again
  • Tried re-attaching monitor
    • Network issues again where loading google.com would take around 20 seconds and refreshing the page would also take several seconds
Clearly there is an issue with the external display. The display is a 1080p monitor which is connected via a HDMI cable and a Mini DisplayPort to HDMI adapter. The strange part is that this problem has never come up before, though in hindsight I would say that browsing at the office has been generally a little bit slower than at home.
Has anyone else experienced this issue? I might try to get an older pre-1.4 spec HDMI cable to see if this has an effect.
    2017-07-20T15:41:40+00:00
    What works for me is moving slightly the dock connector until I get the wifi back. Is like a bad contact alignment happening. Weird but works for me after trying every solution given in this thread with no success.
    2017-07-16T21:16:29+00:00
    Hey,
    same for me I did try every solution which was mentioned here. Nothing worked for me unfortunately. Still surprised Microsoft isn't doing anything about it
    2017-07-16T21:08:25+00:00
    None of it works. And even if it did it is incredible Microsoft has not reponded with a proper fix.
    2017-07-14T21:31:44+00:00
    I don't have a dock cable, but why not try wrapping it? Or you might try what Bersant suggests below
    Hi all
    I had the same problem and found the SOLUTION.
    When I plug in the Surface Dock I need to plug it in so that the wire is hanging on top (so plug the cable with the head of the cable facing down). This way the Wi-Fi works when connected to the new surface dock. If plugged differently it does not work.
    This solution works for me - please try and see if it solves the problem.
    Bersant
    2017-06-22T22:29:42+00:00
    Having the same problem, has anybody from Microsoft given any solution? Is there an fix underway?
