WiFi/Networking issue when connected to docking station
2015-12-16T10:29:24+00:00
I recently bought the new Surface Pro 4 (i7, 512 GB SSD) along with the new docking station. I've experienced some of the general issues that various other people have mentioned (such as the power management/sleep issue) but I'm also seeing an issue that does not yet seem reported.
When I have the new docking station connected, if it's connected to a monitor, the network connectivity sometimes drops. I have been using it without any issues for about 2 weeks, but today I had a lot of trouble connecting to the office WiFi network. The network itself was definitely working properly as it was quick and reliable for several other users, including my own phone. Nonetheless, I rebooted the router to make sure.
Windows simply would not connect to the WiFi network (even though it has always been a saved connection). Trying to connect caused it to sometimes fail and sometimes ask for the network password (and entering it correctly would still fail - but that's another long-standing Windows bug!). Connecting to alternative networks did exactly the same; it would attempt to connect to my phone's portable hotspot, connect and disconnect in a few seconds, retry, and then stop (in a disconnected state). Intermittently it would connect to the network, but sometimes with 'No Internet' and clearly lots of DNS issues in trying to resolve google.com. It sometimes took 30-60 seconds to load google.com.
Troubleshooting steps
  • Tried disabling and re-enabling the WiFi adapter
  • Tried restarting Windows 10
  • Tried disabling all other network adapters (the Ethernet port from the dock and two created by VirtualBox)
  • Tried removing dock connection
    • This is the first time the connection issues were resolved and google.com was loaded (and could be reloaded) within milliseconds
  • Re-attached dock and tried removing Logitech unifying receiver (the only USB device plugged in)
  • Tried removing monitor
    • Everything back to normal, was able to browse very quickly again
  • Tried re-attaching monitor
    • Network issues again where loading google.com would take around 20 seconds and refreshing the page would also take several seconds
Clearly there is an issue with the external display. The display is a 1080p monitor which is connected via a HDMI cable and a Mini DisplayPort to HDMI adapter. The strange part is that this problem has never come up before, though in hindsight I would say that browsing at the office has been generally a little bit slower than at home.
Has anyone else experienced this issue? I might try to get an older pre-1.4 spec HDMI cable to see if this has an effect.
    2017-02-04T10:08:44+00:00
    I spoke to soon.  Shortly after posting this the problem returned.  Thought I'd give it a while before updating.  I don't know what is going on with this issue or why Microsoft cant resolve it.  Although I like my Surface Pro 4 it really hasn't lived up to my expectations overall and I've spent way to much time troubleshooting this issue without any satisfactory result.
    2017-01-14T22:19:03+00:00
    Just to interject here. The only solution is to buy a cheap wireless adapter and plug it into the dock. I bought this one from Amazon - EDIMAX EW-7811UN Wireless USB Adapter, purely because I use it in my Raspberry PI. It works fine.
    2017-01-14T20:58:17+00:00
    Tried all that no go what's puzzling me is I can connect to the dock with ext monitor switched off and wifi works but as soon as I switch the monitor on the wifi goes down no internet connection.
    2017-01-14T20:18:33+00:00
    I can recommend 3 updates for a new Microsoft Surface Pro 4 machine:
    1. Microsoft Windows 10 Updates (found in Settings).
    2. Surface Pro 4 updates (https://www.microsoft.com/en-us/download/details.aspx?id=49498).
    3. Go to ( https://www.microsoft.com/en-us/download/details.aspx?id=46703). Download each fo the software there and install if  not all try at least surface diagnostic toolkit and SurfaceDockUpdaterSetup.msi
    2017-01-14T20:11:40+00:00
    Yes tried that at least 3 times been reading about a problem with usb3 causing a problem with WiFi but if that was the case why does it work with a usb WiFi adapter plugged into the dock.
