thank you .. I will look into the Dell XPS
I am a trainer and the idea of a well functioning tablet - well..
thank you.
nancy
So I've purchased and exchanged 3 brand new surface pro 7s in the last 20 days from best buy because of this issue. Everytime I plugged in the charger, within 5 mins, the backside of the Surface pro 7 starts overheating to an uncomfortable temperature. This was the case for the last 2 Surface Pro 7s as well. Their respective lot number was 1945 and 1943. I'm beginning to wonder if this is an issue with this particular batch ... Is there any answers for this?
thank you.
nancy
I'm sorry to hear this. I have used three Surface Pro models from latest three generations and they all suffered this heating issue. I really love this design but now I made my mind not to buy the next gen Surface Pro, instead switch to Dell XPS 13" 2 in 1 model. That would be my advice.
Lucky you bought it at Costco. I supported local and the only thing they would do for me it to try to fix it or return it to the company.
I just bought the SP7 two days ago. It has been overheating since I just started using it. It's overheating while charging and still overheat after I unplugged the charging cable. I can't even touch the back of the device. I even reset it a few times and delete all games and apps that came with it at initial setup. I force myself to like this device....but if this doesn't improve in the next few days, then I'll return it back to Costco and buy an iPad instead. So, disappointed.
Join the club. Exactly what happened to me. And the store i bought it from won't take it back.
