Battery Degradtion : Surface Pro (5 , 2017) (I5, 256 gb)
2019-06-15T07:08:49+00:00
I just wonder if some of you who own this version of Surface Pro have the same issues like mine as in below:
ISSUE: Battery at full charge drastically degraded and swingsConditions observed lately:-The battery runs out within 1-2 hrs just by browsing websites/Youtube (tested on both Chrome&M. Edge)
-To fully Charge, takes only around 20-30mins (Est. full charge not accurate)
-Battery sometimes drops by a ridiculous amount E.G. by 20-30% in 1 sec.After checked with Battert Report run in CMDAt Designed Cap at : 45,000,
My Full Charge history as below (Noted that i tried to reset the windows and all previous history is gone so this is what i remember)
First bought (Jan,2018)
Full Charge 2018                                 : around 40,000 0 44,000
Full Charge 2019(Early months)          : Starting to drop to 35,000
Full Chrage as of the last few months : 25,000
Full charge as the last few days of notice: Swings from 22,000 to 9,000 life cycles at 383
Now i cant use it outside without charger. This is very frustating while working**.**
As my device is out of warranty, after searching online, the onl way is replacement at 500USD which seems ridiculus to me just because of battery. I bought this expensive device for the reason of long-term use. this is just a year and a half. Shouldn't it last for 4-5 years for its price?
If you have the same issues and any solutions/suggestions, feel free to share and discuss.
**Update 1 8/19/19:**I can't turn on. I lost my files those i didn't back up. I don't have any other computer to use.
Update 2 8/22/19: I just bought a new PC just to work. I cant wait for 1-2 weeks (Send to another country as  there's no microsoft HQ in Thailand) and spend 500USD for just battery replacement.
I kinda gave up and thought it was my fault back then. Now, if you have the same problems. Please up vote.
Update 3 9/1/19:
Seems like my battery is completely dead after testing at a computer shop.
Conclusion:
I am not a hardcore user. In less than 400 cycles, battery (all 4 cells) is dead.
The battery life of my surface pro lasted less than 2 years.
That means you have to pay 500 USD every 2 years. (Could have used this money to upgrade lol)
Maybe 2 in 1 tablets/laptops are not ready for practical use.
Maybe other brands are geting better.
Why do we have to refurbish/replace the device for just a battery which shouldn't cost more than 50 USD.
P.S.
For those who cant even turn the device on,
It's either the circuit is broken duee to defect/unfunctional battary
OR
The battery is completely dead
Worst case = both.
    2021-01-24T15:38:41+00:00
    Thank you for the update and please keep posting your progress. Your experience can serve as a guide to us and hopefully lead to a widespread response in many countries that will finally yield our deserved results.
    2021-01-24T11:08:57+00:00
    Incredible. They keep ignoring it. The rest of us should do the same on our respective countries. They won't listen unless we go against them. Its obvious they know about this.
    Please keep us posted. We would love to hear about your progress in this matter. I wish you the greatest success!
    Thank you for taking the time to keep us informed.
    2021-01-24T11:04:34+00:00
    Good Luck! Hope you'll be successful!
    2021-01-24T10:57:33+00:00
    Further to my enquiries the rep at Microsoft would not escalate my complaint.
    Then he re-iterated his offer of a like for like replacement for $470.
    When I explained that this was not MY problem but theirs, and I would not be buying another Surface 5 just to have the same issue appear he closed my support request!
    I shall now be pursuing this matter in the UK small claims courts, having decided that I have a strong case for mis-selling of an item "not as described".
    2021-01-20T14:33:29+00:00
    It seems that they are waiting for that to happen (i hope not).
    Lets hope that they finally hear us. But seeing this post since 2019... it isnt hopeful at all
