What does this even mean? Can someone draw me a picture. I have been dealing with this issue for weeks. Today for 3 hours I have been trying to use my 2 monitors. total waste of day. I regret this purchase. Surface pro 7+
Surface dock 2 not connecting to monitors using usb-c cables
I purchased two new surface dock2 to connect our surface pro 7 to our widescreen monitors using usb-c cables. Neither of the monitors would connect through the usb-c ports.
One monitor is an LG 38WK95C. The other is a Dell ultrasharp U3818DW. The LG monitor previously worked connecting to a macbook pro through the usb-c port.
To be clear, I first connected the surface dock 2 to one of the surface pro 7 devices and connected the Dell to the surface dock 2 through the usb-c. A messages was displayed to the effect that the monitor should be connected through a displayport. The monitor never showed up in windows, although you would get the sound like a monitor was recognized and the displayport message. Using the "detect monitor" feature came back with "no monitor detected".
I then connected the LG to the other surface pro 7 device through the surface dock 2. The exact same behavior occurred.
Windows update showed no updates available. I then manually updated the firmware on one of the surface pro 7 devices. Still no joy.
2021-08-10T18:13:26+00:00 -
2021-07-27T14:24:57+00:00 I think the issue stems from MS not using standard thunderbolt tech in these docks and therefore the usb adapters end up making the connection work as there are some active components in those to assist the feed that a standard "non active" usb-c>hdmi or usb-c>displayport can't perform. Of course if MS used standardized tech in these devices it would be a non issue.
2021-07-14T06:24:04+00:00 Hi
I had the same issue I used surface dock all the time, before I had surface pro3 with old dock for almost 7 years and always use a bigger monitor as an extension. Last week changed my surface to 7 and bought the new dock as the old one was not compatible. Yesterday setup everything and seems fine the problem started when I plugged external display cable to USB-C. I bought USB-C to HDMI cable tested it in the shop with surface it works fine, but when it is connected to Dock 2 it did not work.
My Solution, I bought a USB-C to HDMI adapter, and it works fine. (Connected HDMI cable to USB-C Adapter)
https://www.ugreen.com/products/usb-c-to-hdmi-adapter
So, I believe the issue is with the cable, change the cable and see if it works,
Hope it works for you.
Saeed
2021-07-07T01:38:38+00:00 Confirmo, luego de varias jornadas de trabajo que el dock se comporta de manera normal sin ningún problema... Se reactivan y reconocen las pantallas luego del apagado, reinicio y suspensión... Espero que esta información ayude a alguien.. ya que cuando uno llega a esta página... Llega desesperado luego de haber probado todo
2021-06-23T21:17:47+00:00 Hola a mi me paso lo mismo con la surface dock 2, tengo 2 monitores de 27 pulgadas curvos Samsung, el problema lo solucione cambiando los cables por unos cables Baseus 4k a 60hz, ya que los que tenia eran Moco 4k a 30hz.. la marca de cables que compre es Baseus Video adapter cable Model: NP021180R01BS
Los acabo de comprar hoy como la ultima opción antes de tirar el surface dock a la basura, ahora espero que esta solución sea definitiva aun me falta probarlo en una jornada laboral completa por unos dias. informare los resultados.
*Ah por cierto, tuve que limpiar el registro del dock, ya que me aparecía "Error de controlador"
