Power Cover Not Charging 100% 0% 100% ???
2016-08-27T11:39:33+00:00
I've seen many post, but no answers?  Surface Pro Classic and just bought a Power Cover.  Power Cover is recognized as both a keyboard and a battery under devises.  All firmware ever pushed is there and updated. Battery #1 and Battery #2 show in the battery menu...but not charging or maybe 100% charged is completely depleted.
Once the internal battery reaches 80% (or so) the Power Cover charge goes from 0% to 100% and not charging.  Once the internal battery is depleted, the Surface shuts off and the Power Cover sits there happily doing nothing to help.
Has Microsoft just ignored the many people that this problem has occurred to, or is there not a fix.  I'm trying to hold out till the Surface Go, but this battery thing is annoying to deal with.
Please don't add the gif. of how the batteries charge or how the blue fills the keyboard and monitor, please please don't answer with that.
Surface | Surface Pro | USB-C
    2017-10-15T15:57:48+00:00
    This worked for me too, though I was a bit reckless.  I literally got an old 1A Samsung
    phone charger, cut the end off of an old USB cable, stripped the wires that supply current, cut open the power cover, and touched to the battery connectors in the power cover for about 5 seconds at a time, measuring the new voltage each time until each was well over 3V (took about four or five times each to get them revived to the point that it would charge again). Worked like a charm, though I had heavily protected my hands, face, and body in case something went horribly wrong.  For what it's worth, I can't recommend you do this, but I got to the point of not caring what happened to it if it didn't work (and again, I had gone to great lengths to make sure I wouldn't be injured if a battery exploded).  It's been chugging along fine now for about six months.
    2016-09-25T19:31:37+00:00
    Just bought one to (Brand new) and it does the SAME thing....Help???
    2016-09-22T14:53:47+00:00
    I just got a power cover (brand new) and what your describing is exactly what mine is doing. I have already reset my surface Pro and installed all necessary firmware and updates.¥ have even done the two finger reset and uninstalled batteryandehargierclrivers and did the two finger hard reboot. No change. The surface cover works as a keyboard and mouse but only has the 0% and 100% battery states. (It goes From 0% to loo battery states. (It goes From 0% to 100% in about 5 seconds) I've now resorted to plugging and unplugging the cover with different combinations(connected to charger, dock, no charger).I have done this about 100 times now and no luck
    2016-09-21T12:56:36+00:00
    I am also having this issue. I have tried all the troubleshooting steps I can find. Basically Battery 2: Will show 0% and not charging until I plug in the AC adapter then it immediately goes to 100%. After removing the AC adapter it will still show 100% but will not draw power from the cover, only Battery 1, the internal battery. As stated before If I remove the cover and reattach it will go back to 0% battery again. I have checked all windows updates, running Windows 10. Also tried manually updating the Surface Pro 2 firmware and drivers.
    2016-09-21T02:01:44+00:00
    Exact same issue here, to a T.
