BATTERY DRAIN ISSUE OF SURFACE PRO 6
2019-08-14T06:04:53+00:00
I use my Surface Pro 6 for official work. No heavy usage for the Surface Pro 6, The device is on from morning 10AM to evening 7 PM. After that the device is switched off and kept in the backpack.
But...
After recent update received for Surface Pro 6, I have noticed that the battery is drained by 5-10%. Even though the device is completely switched off then why the drain?? Plus I keep the device fully charged before shutting it off in the evening.
I do-not need the solution like reset the device & there is no heavy RAM usage application installed on the device. I have checked the RAM usage and there is no application as such which can drain the battery.
So kindly give the proper reason for the draining of the battery.
UPDATE 16-08-2019.
I had charged my device 100%; Switched it off completely and since it was holiday I kept my device turned off. Today morning i.e. 16-08-2019 at 10:15AM I switched on my device and the battery was at 84%. So it drained 16% while being switched off.
UPDATE 21-08-2019.
Still facing the problem, but I think I have find out the issue. I thick the issue is that the SURFACE PRO 6 TYPE COVER (KEYBOARD); is draining the battery. I stated this because on 17-08-2019 I had de-attached the type cover from the device and carried it separately. The next morning the battery was not drained at all. I am not 100% sure. But I did see it; I will try it again today. Lets see what happens.
2019-10-11T17:03:21+00:00
They have pushed updates to production related to battery performance per https://support.microsoft.com/en-us/help/4469841/surface-pro-6-update-history
October 2019 updates
October 10 release
The following updates are available for all Surface Pro 6 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 241.1.139.0 Surface System Aggregator – Firmware<br><br><ul><br><li><span>241.1.139.0 helps improve battery life.</span></li></ul>
60 additional answers
    2019-08-17T05:26:26+00:00
    I have Reported that issue on the Feedback Hub application.
    Here is the link.
    https://aka.ms/AA5vlh0
    Kindly do the needful.
    Thanking you.
  2. Barb Bowman 80,810 Reputation points MVP Volunteer Moderator
    2019-08-16T10:15:50+00:00
    All I can suggest is that you use the Feedback Hub App to file a problem report.
    Then get a shared link and post it here (and I will try to send it to an
    internal contact).
    2019-08-16T05:01:33+00:00
    @SPuser1234.
    Yes you're right, even I face the same thing depends on how long the device is kept switched off.
    Please check my edit on the post.
    2019-08-16T01:00:30+00:00
    The recent August driver updates.  after 24-hour period, surface pro 6 battery drains 20% even though it is shut off.
    My guess would be: Surface - Firmware – 239.3101.139.0
