Surface Pro 3 - Missing Surface Pro Touch Controller Firmware after reimage
2014-06-26T13:57:29+00:00
MDT 2013 - Windows 8.1 all updates.
Download surface Pro 3 firmware and driver http://www.microsoft.com/en-us/download/details.aspx?id=38826 to mdt 2013 out of box driver. Reimaged it, but missing only one and most essential driver
UEFI\RES_{e5fff56f-d160-4365-9e21-22b06f6746dd}&REV_0
without this driver, surface pro is just untouchable...can anyone help me to find this driver.
thanks in advance...
2014-06-27T23:39:57+00:00
Hello Orionbelt,
I'm sorry that you are experiencing the inconvenience of this missing driver on your Surface Pro 3. We're here to help.
As this is a pretty technical issue related to a re-image of the device, we suggest you contact our Technical Support Team to help you with this in real-time. You can contact them through chat or phone here.
Thanks for reaching out to us, and please contact us again if you have any other questions.
Best Wishes,
Zack_T
126 additional answers
    2014-12-10T21:20:26+00:00
    My Surface Pro 3 has this yellow triangle for the Touch firmware. I was able to make it go away temporarily - it came back, as others have noted. What I wish to note is that otherwise, my Surface Pro 3 works very well. The touch screen works as I would expect. I have not found one thing it won't do that I expect it to.
    So, while it's annoying this silly yellow triangle is sitting in Device Manager - it's just that; a minor annoyance. My tablet works very well.
    Bye.
    2014-12-10T21:04:47+00:00
    I plan to sit here as they open box after box. If I go through all the replacements I'll ask for a refund (I purchased in 6/2014) or I'll ask them to start opening retail boxes.
  3. Deleted
    2014-12-10T19:43:50+00:00
    I'm heading to my local Microsoft Store with the exact same issue. They insisted it was an issue that reimaging would fix but the yellow triangle is back. I'm going to ask for a replacement today and sit in the store while it does its updates. If the yellow triangle comes back I'll just keep asking for replacements. This is my 3rd Surface Pro 3. They also insist that this is only affecting a handful of users, but I fail to see how everyone they pull out of the box isn't having this issue.
