Surface Pro 8 camera issues; have to constantly disable and re-enable camera driver to get it to work
2024-01-11T15:01:19+00:00
I've had an on-going issue with my surface pro 8 since I first got it about 20 months ago. The camera will stop working, light will stay on. This happens quite frequently, up to a few times per hour sporadically while using the camera. I've only really been bothered by this more recently as I've been using the camera more for work.
Both front and rear-facing cameras will cease working when this happens.
Disabling and re-enabling the camera driver solves the problem temporarily, making me think it's a driver issue. I've previously attempted to uninstall and install the latest drivers to no effect.
Thank you for your time in this matter.
Surface | Surface Pro | Sound and camera
2024-08-28T20:09:00+00:00
Thank you for reporting the issue. A fix is available through Windows Update.  For more information about updates for your Surface available through Windows Update see the Surface Pro 8 update history page.
51 additional answers
    2024-06-07T20:42:59+00:00
    Good news, maybe...
    On June 3 Microsoft finally released a possible fix with June Firmware update (here for Surface Pro 7+: Surface Pro 7+ update history - Microsoft Support)
    Improvements and fixes:
    • Addresses camera's performance issues caused by inadequate memory or storage capacity.
    Windows Update Name Device Manager
    Intel - Camera - 60.22000.5.15512 Intel(R) TGL AVStream Camera - Cameras
    Intel Corporation - System - 60.22000.5.15512 Intel(R) Imaging Signal Processor - System devices
    Intel Corporation - System - 60.22000.5.15512 Intel(R) Control Logic - System devices
    Intel Corporation - System - 60.22000.5.15512 Surface Camera Rear - System devices
    Intel Corporation - System - 60.22000.5.15512 Surface IR Camera Front - System devices
    Intel Corporation - System - 60.22000.5.15512 Surface Camera Front - System devices
    Intel - Extension - 60.22000.5.15512 Intel(R) TGL AVStream Camera - Extensions
    Surface - Extension - 60.22000.5.15512 Surface IR Camera Front - Extensions
    Surface - Extension - 60.22000.5.15512 Surface Camera Rear - Extensions
    Surface - Extension - 60.22000.5.15512 Surface Camera Front - Extensions
    I just installed... Finger crossed!
    2024-05-16T03:01:52+00:00
    Not just a SP8 issue - also occurring with a bunch of SP7's as well. Now checking with my SP6 users to see if they are having issues that they haven't told me about ...
    2024-04-22T14:30:36+00:00
    I previously installed Youcam 365 from the Microsoft Store, then went to device manager, disabled the device and enabled the device again. And the camera managed to work again.
    2024-04-22T14:18:31+00:00
    Same issue. Sometimes it even get stuck when you try to disable it. Sometime it ask you to restart your windows. Wasting so much time and causing too much frustration. I checked. The camera is Intel(R) TGL AVStream Camera. Either MS or Intel needs to update the driver. Stop asking users to restart.
