Surface Pro 8 camera issues; have to constantly disable and re-enable camera driver to get it to work
2024-01-11T15:01:19+00:00
I've had an on-going issue with my surface pro 8 since I first got it about 20 months ago. The camera will stop working, light will stay on. This happens quite frequently, up to a few times per hour sporadically while using the camera. I've only really been bothered by this more recently as I've been using the camera more for work.
Both front and rear-facing cameras will cease working when this happens.
Disabling and re-enabling the camera driver solves the problem temporarily, making me think it's a driver issue. I've previously attempted to uninstall and install the latest drivers to no effect.
Thank you for your time in this matter.
Surface | Surface Pro | Sound and camera
2024-08-28T20:09:00+00:00
Thank you for reporting the issue. A fix is available through Windows Update.  For more information about updates for your Surface available through Windows Update see the Surface Pro 8 update history page.
51 additional answers
    2024-04-20T10:32:42+00:00
    Go to device manager , then disable the camera driver then enable it again.
    2024-03-12T01:05:37+00:00
    Very lucky you. I have the exact SP8 model but the update did not fix the issue. :(
    2024-03-10T19:51:53+00:00
    Going on almost a week with zero camera issues since the 3/4 firmware updates via Windows Update. 100% stable and snappy Windows Hello face sign-in. Sounds like it's not the silver bullet for all SP8 users though. I have the Surface Pro 8 Model 1983 i5 model specifically. These firmware updates seem to have finally fixed the camera issues for this model at least.
    2024-03-05T14:30:44+00:00
    Hey all,
    Give the latest batch of firmware updates for SP8 from Windows Update a try. I installed them yesterday and have seen very promising improvements with camera stability and performance. Here's the specific update versions:
    • Intel - System - 2334.5.1.0
    • Intel - SoftwareComponent - 1.70.101.0
    • Surface - Firmware - 15.0.2473.3
    • Surface - Firmware - 25.100.143.0
