Surface Pro keeps going to sleep every 1-2 minutes of being idle
2013-04-14T03:29:09+00:00
Love the idea behind the Surface Pro, but been having software and hardware issues lately. One of the software issues I've been experiencing is that when my Surface Pro first goes to sleep after a restart and I wake it up, it then begins going into sleep mode every like 1-2 minutes of being idle. I noticed this when reading some news on the internet.
I double checked my power options I have my current power plan (based off Balanced) set to put my Surface Pro to sleep (while plugged in) after 30 minutes of being idle!
Anyone know what's causing this problem? Is this another OS bug in Windows Ei8ht? I've avoided contacting the Surface support team cause every time I've contacted them about technical problems like this, their only solution is to perform a system refresh.
2014-09-12T04:37:53+00:00
go to desktop mode, go to screen saver, if it says blank, 1 minute, change it to none. it fixed mine SP3, Same issue.
66 additional answers
    2013-05-02T16:05:28+00:00
    Please also try Group Policy. Run gpedit.msc from a Charms search and navigate to here:
    Computer Configuration > Windows Settings > Security Settings > Local Policies > Security Options
    Look for this policy in the list: Microsoft Network Server: Amount of idle time required before suspending session.
    Is there an idle timeout set to two minutes or another time?
    2013-05-02T14:36:39+00:00
    This is due to security policies being enforced by an account connected to the Windows Mail app no doubt. Try this process.
    I don't have that option in "User Accounts".  The Reset Security Policies is nowhere to be found in that menu.  Also, the only account I have added to the Mail app are my primary Hotmail account attached to my Windows Account and a POP/IMAP email account.  Only 2 email accounts and neither one are enterprise.
    So, I'm actually doubtful that is the issue (at least for me).
    2013-04-22T14:40:18+00:00
    2013-04-21T20:47:05+00:00
    Greetings MrElectifyer,
    I am wondering if you create a new Local account on your Surface, if the issue will continue to persist onto the new user account.
    1. Swipe from the right
    2. Touch Settings.
    3. Touch Change PC Settings.
    4. Touch Users.
    5. Touch Add a user.
    6. Touch Sign in without a Microsoft account.
    7. Touch Local Account.
    8. Name the account.
    9. Set a password (optional).
    10. Touch Finish.
    11. Swipe down to close the Change PC Settings window.
    12. Touch your account icon in the top right corner.
    13. Touch Sign Out.
    14. Sign in with the new account you created.
    On this account, set the power options for dimming the screen and turning the screen off, to be different than the default settings. Please let me know if the new account uses the Default settings, or if the settings you set are used.
