Surface Pro 7 randomly freezes while using the Zoom app
Brand new surface pro for about 2 weeks and I've experienced some random freezes while using the Zoom teaching app. For some reason, each time this happens the audio continues to work but nothing on the surface screen or keyboard is responsive and I'm forced to shutdown and restart each time. Support recommended that I run a recovery tool but that didn't do anything to fix my problem. Does this sound like more of a Zoom problem or a surface problem?
Anyone else have a similar issue and fixed it?
2020-04-10T14:43:18+00:00 -
2020-04-09T23:25:15+00:00 Niether worked for me, unfortunately. Also, the surface pro has a front-facing camera.
2020-04-09T21:33:54+00:00 Hi Haiachi7,
Thank you for reaching out to Microsoft Community.
Have you tried checking with Zoom if they have an updated version of the app?
Where did you install the Zoom app, from the Microsoft Store app or through Zoom website installation?
I'm not sure if you have tried but if not, please try these steps to troubleshoot the issue:
1: Run Surface Diagnostic Toolkit and check Windows Update
2: Run System File Checker Tool in Windows 10
If this answer your question, we highly encourage you to inform our Community by clicking on Yes or marking my post as an answer. This will help other members who may have the same issue as you. Otherwise, don't hesitate to update us so we can further assist you.
Kind Regards,
Marrion Y.
Hi Marrion, I wasn’t sure if I was meant to reply yo your post or Kristie’s. If you can please look at my post and advise. Also if you can please advise whether you recommend downloading zoom from Microsoft Store instead of snywhere else? Thanks
2020-04-09T21:24:59+00:00 I have the same problem. Glad to hear it’s not just me! Please let me know what works to solve it.
2020-04-09T11:56:05+00:00 Hi. I have a couple of questions:
- Which Zoom app is better to install on Surface Pro 7... through Microsoft Store app or Zoom website?
- With a rear facing camera, do you need to be facing the camera in order for others to see you? If so, then I wouldn't be able to see others if I am unable to look at the screen?
Thank you
