Surface book 2 15 inch 256G super low wirte speed
2017-12-18T02:23:09+00:00
My surface book 2 (15 inch, i7, 16G, 256G ssd) shows high read speed (~3000 mb/s), but super low write speed (~330 mb/s).  I returned my 1st one due to this super low write speed, but 2nd one also show almost same benchmark speed. Based on other reviews, these numbers are consistently reported in 256G ssd model. I wonder if this write speed is normal or it can be improved by firmware update later. If this write speed is normal...why MS used this ssd?. 300mb/s write speed is much slower than my 2yr old surface pro 4 256G (~1000mb/s) and 3yr old 256G ssd(~800mb/s) in my desktop....
    2018-04-30T15:47:57+00:00
    Really?!  What are your new read/write speeds?  Can you tell me where you got that driver?
    Thanks a lot!
    2018-04-30T15:46:47+00:00
    I found by replacing the Surface NVE Driver with Samsungs driver, it cured my problem.
    2018-04-06T15:40:49+00:00
    I have the same problem with my 13 inches 256 SB2. high read speeds almost in the neighborhood of 2500 MB/s but almost unacceptable write speed (330 MB/s). I don't know the cause of this issue but I need a reasonable answer from the surface team.
    2018-03-31T19:18:20+00:00
    Would like to know this to.. just got a surface book 2 as it just released in Spain and really bothered by the low write speeds in the device.
    2018-02-12T09:27:45+00:00
    Any update on this issue? What are Microsoft doing about it?!
    Good question: I would like to know the answer to this, too.
    I have already returned 2 x SB2 due to this issue and am about to return a third unit. Whilst I generally like this machine, I really do need the connectivity. Without it, in practical terms, this cannot be considered 'portable'.
