Surface Pro 7 display brightness does not chage
2019-11-21T22:50:00+00:00
Anyone has the same issue as me?
When I change brightness with keyboard it does change to 30-50% only (no visible change).
When changing in side swipe, with touch it allows me to change 0%-100% (no visible change)
I tried with nigh mode off... no change
Tried windows setting ... no change
Ambient light On/Off... no change
Can anyone help?
Marek
    2021-02-26T21:11:54+00:00
    This did the trick beautifully! Thank you.....
    2021-02-19T16:36:53+00:00
    I used the intel driver assistant as previously suggested by Marilyn. Located here. https://downloadcenter.intel.com/download/28425/Intel-Driver-Support-Assistant
    It updated everything and I actually keep it running now so it can keep it up to date. Everything is smoother now. I can't recommend it enough.
    2021-02-19T12:31:33+00:00
    This made my screen really small but it didn’t fix the brightness problem.. how can I get my screen back to the way it was?
    (Also any other suggestions for the brightness issue?)
    2021-02-05T05:22:25+00:00
    Thank you, this worked for me too. Though, I had a slightly different problem in that the brightness slider actually disappeared from the display settings. There was also no check box for 'change brightness automatically when lighting changes.' It was just gone. Also, the slider in the system tray was completely grayed out. Everything looks good now after uninstalling the driver and restarting.
    I have this problem too! did you figure out how to fix it?!?!?
    2021-01-30T15:02:33+00:00
    I followed all these steps and restarted but once it came back on, it was only brighter and I still couldn't change the brightness settings.
