This was extremely helpful. Thanks.
Surface Pro 7 display brightness does not chage
Anyone has the same issue as me?
When I change brightness with keyboard it does change to 30-50% only (no visible change).
When changing in side swipe, with touch it allows me to change 0%-100% (no visible change)
I tried with nigh mode off... no change
Tried windows setting ... no change
Ambient light On/Off... no change
Can anyone help?
Marek
2021-01-24T22:55:03+00:00 -
Deleted
2021-01-11T17:52:46+00:00 Tried this several days ago. It didn’t work.
I’m returning it. I’m buying a macbook air :)
2021-01-11T17:31:13+00:00 THIS DID NOT WORK EVEN A LITTLE BIT!
Now everything on my screen is tiny and I still can't change my brightness. Unless anyone here has a real solution, this was all a waste of time and I'm just gonna call tech support because I can't live like this.
2021-01-07T12:50:46+00:00 I am about to try that as well. Do I have to install the Intel(R) Irish(R) Plus Graphics" again afterwards or just leave it?
Thanks already :)
