It seems from the thread that it's not just a SB2 issue. Its happening with a dell and also a Mac???
Surface Book 2 audio - Crackling sound in Zoom meetings
Hello Microsoft Community,
I am experiencing exactly same issue as highlighted in this post;
When I am in a Zoom meeting with 1 person it appears ok - but when a meeting with multiple attendees (hence higher CPU load) are in progress all of sudden other participants get loud crackling noise when I speak, and it has happened on a regular basis.
I have used both
- the built in mic array, as well as
- a separate Logitech USB headset & a Plantronics USB headset
but when the crackling jumbled sound starts to occur, it doesn't matter which mic I am using - and it continues on and off.
I have updated the drivers to the latest packages available, but the issue persists.
I have seen a post talking about unchecking "Enable audio enhancements - Signal enhancements" on Reddit
https://www.reddit.com/r/Surface/comments/3dgdkw/how_to_fix_audio_cracklingdistortion_on_surface/
but I don't see that option in my Surface Book 2 13" i5 model (with the latest Windows 10 patches)
However I do notice a checkbox with "Enable Hardware Acceleration". If I uncheck the box what would it do?
Regards,
Jihong
Surface | Surface Book | Sound and camera
2020-06-07T14:05:08+00:00 -
2020-06-07T12:36:01+00:00 Unpicked noise suppression still cracking sound.
Strange thing is it happens with all mic sources, internal Realtek, 3.5mm wired headphones, USB mic and even BT headset.
2020-06-06T01:12:17+00:00 Yes, same. Did all that with no permanent fix. In this thread there was a fix offered a couple of days ago. It had to do with unticking noise suppression. I haven’t tested it yet. It fixed it for another Surface user. Of course i have my doubts but let’s see. And, yes, no problem using other platforms.
2020-06-05T15:25:37+00:00 I have now gone as far as a fresh install of Windows on my Surface Book 2, still the same cracking noise in Zoom and a message about low system resources no matter what mic and headset I use, built in wired or BT. No noise problem with SfB or Teams.
2020-05-28T04:50:07+00:00 Exactly my problem. Been working on this for six weeks. Have spent hours and hours with Microsoft support. They even sent me a new (same specs) Surface Book 2. I get either the Darth Vader loud weird voice (people say) or the usual crackling and breaking up. I’ve given up, Once used blue tooth head set/mic and it worked, but not the next time. It only happens with Zoom. Not Skype. Not sure about Team.
