Surface Book 2 audio - Crackling sound in Zoom meetings
2020-04-15T05:20:04+00:00
Hello Microsoft Community,
I am experiencing exactly same issue as highlighted in this post;
https://answers.microsoft.com/en-us/surface/forum/all/surface-book-2-microphone-starts-crackling-after/0f27fa1b-3bec-4927-8c5b-303522bad118
When I am in a Zoom meeting with 1 person it appears ok - but when a meeting with multiple attendees (hence higher CPU load) are in progress all of sudden other participants get loud crackling noise when I speak, and it has happened on a regular basis.
I have used both
  • the built in mic array, as well as
  • a separate Logitech USB headset & a Plantronics USB headset
but when the crackling jumbled sound starts to occur, it doesn't matter which mic I am using - and it continues on and off.
I have updated the drivers to the latest packages available, but the issue persists.
I have seen a post talking about unchecking "Enable audio enhancements - Signal enhancements" on Reddit
https://www.reddit.com/r/Surface/comments/3dgdkw/how_to_fix_audio_cracklingdistortion_on_surface/
but I don't see that option in my Surface Book 2 13" i5 model (with the latest Windows 10 patches)
However I do notice a checkbox with "Enable Hardware Acceleration". If I uncheck the box what would it do?
Regards,
Jihong
Surface | Surface Book | Sound and camera
    2020-07-17T02:29:41+00:00
    Think I may have solved this.
    In Zoom, there is a setting for allowing the computer to adjust the mic level.
    When I turn this off, I no longer have the problem.
    I am guessing the mic is quite sensitive and starts pickling up more and more souind if you quiet for a period, then when you speak it's way too loud and distorts terribly.
    You will find this in Zoom settings, audio, under mic level.
    2020-06-03T20:40:17+00:00
    Well, that is one fix I don't think I did try.  thank you and let's hope!
    2020-06-02T12:08:36+00:00
    Unticking Noise suppression seems to have resolved the problem for me for now. Found it in Sound Control Panel - Recording - Microphone Array - Properties - Enhancements - Untick Noise Suppression.
    Hoping it stays that way. Will keep you posted if anything changes.
    Wow that's pretty cool they replaced your machine. Maybe I should try getting one too ;)
    2020-05-23T01:05:52+00:00
    Interesting. I haven't noticed any correlation with certain activities. I'll pay more attention now! But yeah really not acceptable for such an expensive laptop.
    If it helps you, since posting my original message, I've been using an external microphone plugged into the usb and that seems to have solved the issue. I happened to have access to one which made it easy for me.
    2020-05-04T14:59:45+00:00
    If none or still issue persist, please try these steps first:
    1: Run Surface Diagnostic Toolkit and check Windows Update
    2: Run System File Checker Tool in Windows 10
    Tried running SDT and SFC as recommended above, no violations found, could it be because of Windows Pro Insider Preview, is it worth rolling back to try and resolve? I have had this problem now for the past month or so and tried everything including stopping almost all other programs in the calls.
    I have tried with hardware acceleration in Zoom on and off and with Zoom on the integrated GPU and on the Nvidia GPU.
